Have done this before when adding another coat of wax was a lovely sunny evening perfect for a top down drive but I was over the limit when I had finished
Critique my detailing plans
- GAZA62
T.SILVER 2004 3.0SE AUTO
IF IT WAS NOT FOR BAD LUCK I'D HAVE NO LUCK AT ALL
- step_change
I need to detail my E89 as well. Going to do it when I get back from holiday. I have used this regime on various cars for many years and it woks brilliantly and I get fantastic beading. I do the car in "sectors" and complete one sector before going on to the next.
The sectors are: Roof (E89 obviously); , bonnet, front and wings; midsection; rear and boot.
1. Wash thoroughly. The wash of its life. Get into all the nooks and crannies and get all the s**t out. Rinse and dry with car CLEAN towel.
2. Decontaminate with Bilt Humber and let soak for 5 minutes. Use rubber gloves because it stinks and the smell stays on your hands for days afterwards if you don't!
3. Wash again throughly and dry with car towel
4. Clay bar with clay bar lubricant. If you drop the clay bar bin it and use a new piece. After this the panel should be smooth like glass
5. DA polishing machine with chemical guys pads. Don't need to spend too long unless your swirl marks are very bad. 10 minutes per panel is ample usually and often ten mins is enough. Maybe 20 on the huge Z4 bonnet/hood. I do not advise beginners use a rotary polisher, it can end in tears (got that T-shirt)
6. Sealant
7. Wax
8. After every wash use instant shine.
Redo that every year.
6. Sealant
7. Wax
Gone : 2013 35is, Melbourne Red, DCT, Nav, Comfort pack
Gone: 2007 2.5is, Montego Blue, Auto, Nav
Basically just done the above today, the only difference being a ceramic coating rather than a traditional sealant. A long day's work but looking lovely now!
- 20190518_195827.jpg (278.87 KiB) Viewed 1011 times
- 20190518_195841.jpg (191.62 KiB) Viewed 1011 times
- longshaw
+1
No. 5 - If DA is not possible and you have to polish by hand - Get a few of these https://www.cleanyourcar.co.uk/ultimate ... applicator
- saj77
Thanks for the info - no DA, so just bought a couple!longshaw wrote: ↑Wed May 29, 2019 5:28 pm No. 5 - If DA is not possible and you have to polish by hand - Get a few of these https://www.cleanyourcar.co.uk/ultimate ... applicator
08 3.0 SI Roadster - Space Grey / Dream red, Eibachs & B4s, Z4M alignment
