Evian Water for final rinse
- ph001
Distilled water would be better than Evian but I guess thats why quick detailer sprays were invented.
- Crazy Harry
As the post by ph001 above its just distilled water as a by product of dehumidificationHuzee4 wrote: ↑Mon Mar 25, 2019 10:39 amI occasionally use a leaf blower to dry the Zed, the cable is a pain in the arse and I've considered a petrol one just for the job. Always use a Karcher window vac on the glass. Intrigued by the dehumidifier water though, is this really effective ?road warrior wrote: ↑Sun Mar 24, 2019 9:25 pm I have a gizmo made by someone that takes ionised water that you connect the hose to, same principle as the evian water idea.
I also have Wet and dry suck and blow vacuum that I was cleaning the car with one day. After washing it , for shits and giggles I put the vacuum on blow, and guess what - it only worked.... My zed had a blow dry....
- PerryGunn
We're in a fairly hard water area - 272.5 - but have a Harvey's water softener which reduces the mineral content appreciably. We have two outside taps, one direct from the mains and one for softened water which I use for car washing.
If you leave the softened water to air dry, which I tend to do with the X3 as it lives outside and is Cindy's DD, the softened water doesn't give a perfectly spot-free finish but any faint spots that are left are easily removed by a quick wipe-over with a QD.
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
Yep, not saying Evian is the best thing for this, but it's 100% better than the tap where I am. I've been thinking of getting a resin bottle as that is probably the best thing to get, but if I can get some 100% distilled water cheaply then this will do the trick nicely!
People who don't detail, will be reading this thread and going WTF...!
- flimper
Don't worry the saharan rain will take your mind off it soon!
- IMG_0270.JPG (256.47 KiB) Viewed 1027 times
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
- RustyZ4
I cant believe I just read a thread on what water to clean your car with
Z4 E85 3.0, gone but now with son
- GAZA62
but i dont think this an April fools
T.SILVER 2004 3.0SE AUTO
IF IT WAS NOT FOR BAD LUCK I'D HAVE NO LUCK AT ALL
- Jembo
Would of been if was ‘Peckham Spring’
Lifer 54
Lifer 54
