Wheels - Wonder Wheels or something else?
- Mr Tidy
Well I'm not often found on this part of the forum, but I recently bought another set of wheels (probably going on my 3 Series) and although I've washed them there are a few patches of stubborn dirt.
I'm sure I read somewhere that some wheel cleaners are acidic which can cause problems, but I have some Wonder Wheels?
Would it be OK to use this, only I don't want to cause more harm than good?
Any other recommendations would be appreciated.
Many thanks.
Many thanks.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- mr wilks
Wonder Wheels is acidic , if you use it wash off immediately , im not a fan of any wheel cleaning agents , they don't remove brake dust with a magic potion
Id try AG SRP first if you have some
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Try Dragons breath Stinks like hell, hence the name but first class stuff
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- Mr Tidy
Thanks guys.
So Wonder Wheels doesn't look like a good idea then!
I don't have any AG SRP, but even if I did I think it would be hard to actually get to apply it to where the dirt is (wheels are CSL reps and it's on the rims between the spokes).
I did read somewhere about Bilt Hamber Auto Wheel Cleaner which claims to be PH adjusted, so maybe that's worth a try.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- MrPT
Are you sure it’s dirt? If it’s brake dust build up you might need something like Dragon’s Breath or Iron Out. Iron Out stinks too.
Would try something SRP first though and then move onto something more potent if that doesn’t work. You could also try a small piece of claybar if the wheels haven’t been resprayed.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
I have used this in the past Iain and like most of their products it is good. Mind you it doesn’t smell very nice. I use their their clay bars too.Mr Tidy wrote: ↑Mon Jan 14, 2019 10:04 pm Thanks guys.
- BeeEmm
The attached link is what you need, although 'Dragon's Breath' is a similar product. https://www.bilthamber.com/car-cleaning ... g/korrosol This is Bilt Hamber's website, there are lots of great products here for preventing rust to waxing your car. It is worthwhile having a look at all their products. Get yourself a wheel brush to get in between the spokes and crannies.
I used to have two boys and a girl. Now I have two Men and a Woman.
- Mr Tidy
Really helpful replies - cheers!
The build-up isn't so much between the spokes, I'm not sure how to explain it but it's mostly on the lip on the rims between the spokes - if that makes sense.
Time to experiment I think!
I'm not sure if it will show too well, but I've added a photo of one of the wheels.
- CSL Rep.jpg (250.28 KiB) Viewed 1318 times
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- BeeEmm
It's quite normal for contamination to gather there. Korrosol (or whatever you choose) will shift it. Spray it on, let it dwell for about 4 minutes and use a wheel brush (similar to the attached photo, you can get them cheaper) to agitate it. Rinse of thoroughly, and then wash the wheel, again using the wheel brush to get into those crannies. Don't forget to do the inner barrel as well.
- patriot66
If you need to shift stubborn, accumulated dirt and brake dust then I would recommend Sonax Full Effect Wheel Cleaner...best I've ever used and it's acid free https://www.cleanyourcar.co.uk/sonax-wh ... fect-500ml You can get 500ml for about £8 if you search the web. I buy it in 5 litres for about £60.
When you get them clean if you seal them with a good quality seal or wax etc it will make them much easier to clean next time, often with just regular shampoo and some decent brushes. I sealed mine with Soft99 Fusso Coat as an experiment a few weeks back and it is working superbly
- derin100
Going to give that a go on our X3 wheels because they're really quite bad.Thanks!patriot66 wrote: ↑Tue Jan 15, 2019 6:01 pm If you need to shift stubborn, accumulated dirt and brake dust then I would recommend Sonax Full Effect Wheel Cleaner...best I've ever used and it's acid free https://www.cleanyourcar.co.uk/sonax-wh ... fect-500ml You can get 500ml for about £8 if you search the web. I buy it in 5 litres for about £60.
(I'm such a sucker for detailing products so I just bought some online --- ECP has it at £7.95)
E85 3.0Si Silver on Black (Gone and will be missed)
E85 M Roadster Silver Grey on Black
E85 Alpina Roadster S Toledo Blue on Black
Another vote for Bilthamber wheel cleaner i have found this to be the best.
It will easily sort the wheel in the photo out.
I like Angelwax Billberry wheel cleaner,very good stuff,used it for years
Interlagos Blue M RDSTR,2008. Logic7 dsp Hifi;satnav,stubby,htd seats,etc,etc.
Black 2005 3.0i NOW SOLD(and missed)
- hopz121
Bilthamber Autowheel and a brush as above and don't look back
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- patriot66
derin100 wrote: ↑Tue Jan 15, 2019 11:03 pmGoing to give that a go on our X3 wheels because they're really quite bad.Thanks!patriot66 wrote: ↑Tue Jan 15, 2019 6:01 pm If you need to shift stubborn, accumulated dirt and brake dust then I would recommend Sonax Full Effect Wheel Cleaner...best I've ever used and it's acid free https://www.cleanyourcar.co.uk/sonax-wh ... fect-500ml You can get 500ml for about £8 if you search the web. I buy it in 5 litres for about £60.
