Orange Peel??
Orange Peel??
Still waiting on the Menzerna to turn up
Orange Peel??
So eventually got the menzerna super heavy cut and a flexpad denim pad. The results as below, hard to tell whether its actually improved the orange peel or just made it shinier!. Its hard to show it in a photo but the below does catch some of the problem, should i just suck it up or get it wet sanded, and if so by who and an idea of cost would be very helpful[img]
- 2018-07-20 15.34.33.jpg (344.79 KiB) Viewed 1610 times
Orange Peel??
Hard to say,but that looks in the base coat to me..
Thats heavy peel...
Thats heavy peel...
Orange Peel??
really tricky one...honestly, in my view for a £5k Z4 you have to ask is it really worth spending £1k to 100% perfect the paint. The car looks amazing from what I can see, is that not enough?
Orange Peel??
check the depth of the paint first before anything. You've tried to cut it twice now with denim pads and course polish. I would not want to put 2000 grade wet & dry on that without a measure of the clearcoat.
Unless of course you are willing to spend on getting it painted when it all goes wrong.
- Lynchy
Orange Peel??
As someone has already said the orange peel will be the lacquer. You need a block and 2000 w n d. A machine polish with a cutting compound will sort that out. Perhaps you need to get someone that knows what they are doing.
Orange Peel??
If there's any clear left after all that polishing.
Orange Peel??
Well its a 10k car but would have though colour sanding a bonnet would be at most a days work. Agreed re the depth of paint but surely if a bonnet has been repainted its unlikely to be a bare metal respray so there could be 2 lots of basecoat then clear coat on it so it would be still easy to go through the clear coat. Lynchy can I pm you re this??
- Lynchy
Orange Peel??
Yes you canBluecat wrote: ↑Mon Jul 23, 2018 10:45 pm Well its a 10k car but would have though colour sanding a bonnet would be at most a days work. Agreed re the depth of paint but surely if a bonnet has been repainted its unlikely to be a bare metal respray so there could be 2 lots of basecoat then clear coat on it so it would be still easy to go through the clear coat. Lynchy can I pm you re this??
Orange Peel??
Ok After much pondering ordered some 1500 and 3000 grit Trzact discs with a soft foam insert to go on the DA. It is possible to wet sand with a DA but you have to just use a water spray mister on the pad and a couple of squirts on the panel. Below are the attempts so far with 1500 grit doing quarter of the bonnet a time. I know have half a matt bonnet, will press on with the rest tomorrow then 3000 grit. Then the final stages are compound and then polish. If I dont post any more photos its all gone horribly wrong NB the first photo is the last, not got the hang of posting pictures very well yet. The third and fourth photo show the extent of the orange peel.
Orange Peel??
Bluecat wrote: ↑Sat Aug 11, 2018 5:52 pm EXPAND VIEW TOPIC REVIEW: ORANGE PEEL??
Orange Peel??Quote Bluecat
by Bluecat » Sat Aug 11, 2018 5:52 pm
Ok After much pondering ordered some 1500 and 3000 grit Trzact discs with a soft foam insert to go on the DA. It is possible to wet sand with a DA but you have to just use a water spray mister on the pad and a couple of squirts on the panel. Below are the attempts so far with 1500 grit doing quarter of the bonnet a time. I know have half a matt bonnet, will press on with the rest tomorrow then 3000 grit. Then the final stages are compound and then polish. If I dont post any more photos its all gone horribly wrong NB the first photo is the last, not got the hang of posting pictures very well yet. The third and fourth photo show the extent of the prange peel.
2018-08-11 17.31.25.jpg (271.8 KiB) Viewed 1 time
2018-08-11 16.30.40.jpg (275.17 KiB) Viewed 1 time
2018-08-11 16.06.31.jpg (239.09 KiB) Viewed 1 time
2018-08-11 16.05.52.jpg (256.89 KiB) Viewed 1 time
Orange Peel??Quote Lynchy
by Lynchy » Tue Jul 24, 2018 1:36 pm
Yes you can
by Bluecat » Mon Jul 23, 2018 10:45 pm
Orange Peel??Quote Anmarube
by Anmarube » Mon Jul 23, 2018 10:14 pm
Lynchy wrote: ↑Mon Jul 23, 2018 5:23 pm
by Lynchy » Mon Jul 23, 2018 5:23 pm
by Anmarube » Mon Jul 23, 2018 4:30 pm
Orange Peel??Quote Angelus666
by Angelus666 » Mon Jul 23, 2018 4:09 pm
Orange Peel??Quote Z4M-2006
by Z4M-2006 » Mon Jul 23, 2018 4:08 pm
Thats heavy peel...
by Bluecat » Mon Jul 23, 2018 4:02 pm
2018-07-20 15.34.33.jpg (344.79 KiB) Viewed 60 times
by Bluecat » Mon Jul 16, 2018 10:39 pm
by Lynchy » Sun Jul 15, 2018 5:01 pm
Bluecat, I'm about 5 miles the other side of Dartford Tunnel into Kent . I have been a S.M.A.R.T repairer for many years. If you want to come to me I'll take a look at your paintwork and offer you very good advice
by Bluecat » Sun Jul 15, 2018 4:33 pm
Thanks Russell, will do
Bruce
by Anmarube » Sun Jul 15, 2018 1:11 pm
Bluecat wrote: ↑Sun Jul 15, 2018 11:22 am
Ealing ! Its about 100 miles away, waiting on the menzerna heavy duty 300 polish but if that does not do it, any help would be much appreciated I could get to you easily enough
No worries. Drop me a PM if it doesn't work out for you
Russell
by Bluecat » Sun Jul 15, 2018 11:22 am
by Anmarube » Sat Jul 14, 2018 10:54 pm
Bluecat wrote: ↑Fri Jul 13, 2018 5:55 pm
The bonnet looks to have been blown over at some point, there are not that many stone chips, and the orange peel is pretty much all over the bonnet. Having said that bmw paint quality is not good, my neighbours 2017 x3 has similar orange peel, so it possibly could be the original but doubtful. I thought if you leaned hard on a DA it slowed down so surely it must polish it less? Dont want to go through the clearcoat but attempts so far have not yielded much change.
Whereabouts are you pal. I will help out if not too far.
Top
Board indexDelete all board cookiesDonations All times are UTC+01:00 Powered by phpBB® Forum Software © phpBB Limited
Style we_universal created by INVENTEA & nextgen
- Lynchy
Orange Peel??
Looks good so far
Orange Peel??
Thats not orange peel...
Its elephants skin.
Its elephants skin.
Orange Peel??
Phew that was a faff. Luckily it came out all ok and orange peel now gone
Orange Peel??
looks like a good finish...nicely done!
