How does this happen?
Went to my car today and noticed someone had dinged my rear arch, causing this weird nipple like bump just above the dent. Anyone seen this before?
- 20180518_191117.jpg (228.29 KiB) Viewed 1843 times
2003 Sterling Grey 2.5i - RHD car living in a LHD country.
- srhutch
- Moderator
Must be a reinforcement point behind, double skin, something like that. So when the panel was pushed in that stayed put and pushed out.
- ronk
It looks like you’ve had something un tethered In the boot?
- jabber
+1
Z less again
- JimsZ
One of those mobile dent repair companies will put the pride back in your pride and joy
It will cost you about £100 though
E89/28i Msport gone .. Zx10r track bike gone… time for a KTM 350 exc-f and some green laning and dirt bike excursions…. Let’s see how this goes… :
- srhutch
- Moderator
Your Zed needs a good squeeze, remember it's a teenager now and is starting to get spotty .
That looks like an inside to outside dent when you 1st see it, but what srhutch has pointed out, makes it a bit weird.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- patriot66
Watch this video. It explains a little about internal structures causing external panel damage as well as shedding quite a lot of light on the art of PDR. https://youtu.be/hcIA2vi86bc
- Ducklakeview
THAT is some skill..patriot66 wrote: ↑Sat May 19, 2018 10:12 am Watch this video. It explains a little about internal structures causing external panel damage as well as shedding quite a lot of light on the art of PDR. https://youtu.be/hcIA2vi86bc
Mike
WOW
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- patriot66
Pure skill indeed. How do you think that glue 'unsticks' itself ? Does it decay over a few minutes and peel off ? Be interested to know.
- Z4C_er
My take on that is that the glue has been applied to the surface with - at the time - a specific shape, and as you pull, the surface changes shape and the glue cannot keep its adhesion due to the new shape so pops off.
What blows me away is hitting the surface IN to pull OUT a dent.... Whaaaa?
2006.5 E86 Z4C si SE Phoenix Yellow
