Safe wheel cleaner?
- dhobbs
Safe wheel cleaner?
I'm after a safe wheel cleaner that can be used as a weekly wash.
I've got bilt hamber which says it's water based rather than acid based.
I've also had my wheels refurbished and sealed with gtechniq so don't want to erode that either.
I normally use car wash but as that can contain waxes I don't want that on the brake disc! I used bilt gambler wash once on the GFs wheels and that was frightening when I first used the brakes .
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
Safe wheel cleaner?
I use Bilberry on my Zed and my diamond cut Mercedes alloys. It's non-acid so is nicer the use, kinder to the wheels, doesn't irritate the skin and also does a good job. I won't use anything else now which means I have 4 litres of autoglym acid based cleaner in my garage.
The bilt hamber you're using should be fine as it non-acid.
2004 3.0i, manual, toledo blue
- dhobbs
Safe wheel cleaner?
Would you recommend it as a weekly wash?csquire4 wrote: ↑Sun May 06, 2018 1:07 pm I use Bilberry on my Zed and my diamond cut Mercedes alloys. It's non-acid so is nicer the use, kinder to the wheels, doesn't irritate the skin and also does a good job. I won't use anything else now which means I have 4 litres of autoglym acid based cleaner in my garage.
- Z4C_er
Safe wheel cleaner?
Normally, if you have your wheels treated then the mildest of washes should suffice, but otherwise I use mild stardrops or in ascending order of cleaning power, bilberry then Bilthamber Korrosol iron remover.
2006.5 E86 Z4C si SE Phoenix Yellow
Safe wheel cleaner?
+1 for bilberry but I don't let it dwell. Spray, agitate with brush, rinse, wash, rinse and only one wheel at a time
Next Z landed ..... Z3 3.0i Sport Roadster
Z4 35iS ..... Gone to a new home
- hopz121
Safe wheel cleaner?
If they are sealed you shouldn’t even need a wheel cleaner..... a bucket of warm soapy water should be fine.
I use Bilt Hamber Auto Wheel which is great but my protection on my wheels is long gone. When I do seal them again I’ll be going back to warm soapy water
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- dhobbs
Safe wheel cleaner?
Ok. I have normally used Muc Off but ran out, hence why I started using AG body shampoo. The muc off does contain any wax as far as I know.
- Mark-Z4
Safe wheel cleaner?
I use this one weekly, ph neutral. I would get 5 litres though as it sprays generously. Brilliant stuff, sometimes I just give the wheels a little exaggeration with a wheel brush and rinse off.
http://www.theultimatefinish.co.uk/bilt ... wheel.aspx
E86 - Space Grey | Grey Oregon Pearl Leather | Sport Interior | ///M Bumper | Aero Skirts | Piano Black Trim | ///M Wheel | Eibach Pro | CSL | HID | LED | ZHP | MM Tips | Stubby SOLD
- GAZA62
Safe wheel cleaner?
Agree you should not need any sort of wheel cleaner I use my regular body shampoo Megs Gold Class but I can clean my wheels with plain hot water if I need tohopz121 wrote: ↑Mon May 07, 2018 8:39 am If they are sealed you shouldn’t even need a wheel cleaner..... a bucket of warm soapy water should be fine.
T.SILVER 2004 3.0SE AUTO
IF IT WAS NOT FOR BAD LUCK I'D HAVE NO LUCK AT ALL
Safe wheel cleaner?
If a good clean is needed before sealing would recommend Dragons Breath (But be warned - Smells as evil as it sounds but great stuff) but once sealant is used wouldn't touch it with anything other than a mild shampoo as already statedGAZA62 wrote: ↑Tue May 08, 2018 5:35 pmAgree you should not need any sort of wheel cleaner I use my regular body shampoo Megs Gold Class but I can clean my wheels with plain hot water if I need tohopz121 wrote: ↑Mon May 07, 2018 8:39 am If they are sealed you shouldn’t even need a wheel cleaner..... a bucket of warm soapy water should be fine.
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
Safe wheel cleaner?
+1 for Bilt. Use it each time I wash the car and accumulated dirt pretty much comes off with the pressure washer and no agitation. Stinks a bit though.
Z4MR silver grey with lots of bits. Now stubby and proud.
Gone: 2007 4 pot Sport. Monaco Blue, cream leather. Whippy and proud.
