I have got windscreen smears where the two blades overlap.
I have just bought new Bosch blades and the smears are still there.
I have cleaned the window with gtechniq g6 but it looks like the smear is coming back.
What can I do to get rid of it for good?
Do I need special cloths or is tissue paper better as it's more abrasive?
Daz
windscreen smears!!!
- dhobbs
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
- cj10jeeper
Is it smears or fine scratches from worn blades?
If the former then I'd use some good old domestic window cleaner or vinegar on a cotton cloth. Might be thicker deposits of rubber that take some removing
- ekimj10
Recently bought these from Amazon as we needed a good smear free finish on bathroom mirrors, the dash wipes were a bonus but both products work very well and the glass wipes should "clear your smear"
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
2.2R Toledo Blue
- dhobbs
It's not scratches but a small section where the two blades overlap.cj10jeeper wrote: ↑Wed Jan 31, 2018 11:25 amIs it smears or fine scratches from worn blades?
I'll give the vinegar a try.
I've tried bar keepers friend, clay bar and a few other cleaners, but it keeps coming back.
Even a problem with gtechniq g5 sealant.
- pvr
I used Cerium Oxide to get rid of a haze on the glass. With a machine polisher.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- ph001
Yeh, it's probably something you need to polish out if the usual alcohol based cleaners don't touch it.
Cerium Oxide is the right stuff to use as PVR mentions but it's fairly pricey and you will need a polisher to do it well (ideally rotary but DA will probably suffice). Your arm will be killing doing it by hand and it's hard to be consistent.
Jewellers Rouge also works but it doesn't have as good cutting capability as Cerium oxide
Frost do a kit that you can use with a drill that has good reviews https://www.frost.co.uk/glass-polishing ... epair.html
- dhobbs
I have the meguires headlight restoration kit. Will that work? It has 4 grades of wet/dry and a cutting compound liquid. Plus it has the drill attachment.
Got my MOT next week so don't want to risk a failure.
- dhobbs
So I've cleaned the window with vinegar and a tea towel (cotton).
Rinsed off then cleaned again with gtechniq g6.
Let's see how that goes tomorrow on the way to work.
