Are all interior cleaners garbage ?
Tried 3 different types, and must be honest it’s hard to see any difference ... apart from the fact I’ve run over the surfaces with a cloth . Or are my expectations too high and interior trim doesn’t come up good from cleaning ?
Tried Meguiars, turtle wax and armour all . All pants .
- buzyg
Cheers mate will give them a go
- ekimj10
I found both the mirror and interior wipes work well.
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
2.2R Toledo Blue
- Paulr
1001 spray carpet stain remover and a stiff brush works wonders on plastics.
If you try and take a cat apart the first thing you have is a non working cat.
- Buckz
I'd say you're trying things that are too cheap. I've used a few products and they'll help get the marks etc off.
![Image](https://i.imgur.com/bTlK7ZT.png)
- GAZA62
I always use Meguires Last Touch great for wiping over interior plastics dries with a nice oem finish also use it for engine bay a QD a clay lube and a drying aid
My interior is kept very clean so no real stubborn stains to remove usually some mud from my boots if I have been to a race circuit.
The Autoglym Synthetic Chamois is great for wiping over the top of the dash
![Thumbs Up :thumbsup:](./images/smilies/smilie_thumbsup.gif)
T.SILVER 2004 3.0SE AUTO
IF IT WAS NOT FOR BAD LUCK I'D HAVE NO LUCK AT ALL
Meguiars APC diluted 10-1 is a brilliant product for interior cleaning.
- Ducklakeview
I use the Autosmart interior cleaner diluted with water, works well and is a LOT cheaper than those "big brands" mentioned.
Mike
Mike
Help the op by letting him know which products you would use.
Z4MC
- Z4C_er
I'm extremely fussy and have settled on the Autoglym interior shampoo. Mind you I use it on mainly the lower trim (pedals, scuff plates etc), but rarely on instrument panel trim. FWIW, apparently APC's should not be used on the interior, esp carpet.
https://www.youtube.com/watch?v=j74n_R-wle8
Basically, for the hard surfaces, I find just using a soft synthetic chamois or if it needs a bit of a clean, then Meguiars detailer with a microfibre cloth works well. Just need a good temperature.
2006.5 E86 Z4C si SE Phoenix Yellow
ODK Cabin is held in high regard over on the detailing forum:
http://dooka.co.uk/odk-cabin-interior-dressing
