check out the images in the for sale section. It looks very much like the stormworks in shape and style except I think better as it has Z4 engraved on the top instead of M. If the dimensions are the same, the weight will be the same. £75 or £32...its a no brainer really.
Custom gear knob
- Davz
Custom CNC machined stainless steel Gear Knob
2006 2.5 Monaco blue, orange footwell lights, Blue boot lights, 20/15mm wheel spacers, Buckley06 gear knob, Aux, MV2's, M pedals, Eibachs, Bilstein B4's, Whiteline front ARB. H&R rear ARB. Roof motor relocated, Alpine speakers, Xenons.
Onlinebuzyg
Unless your peddling an ///MDavz wrote: ↑Sat Mar 31, 2018 2:17 pmcheck out the images in the for sale section. It looks very much like the stormworks in shape and style except I think better as it has Z4 engraved on the top instead of M. If the dimensions are the same, the weight will be the same. £75 or £32...its a no brainer really.
- thanatu55
Not exactly true. There is a certain amount of science behind the Storm Motorwerks to get the weight just right, along with the depth of the opening to allow for a very short throw. It's not just a case of cutting a ball out of steel and putting it on a stick.Davz wrote: ↑Sat Mar 31, 2018 2:17 pmcheck out the images in the for sale section. It looks very much like the stormworks in shape and style except I think better as it has Z4 engraved on the top instead of M. If the dimensions are the same, the weight will be the same. £75 or £32...its a no brainer really.
- thanatu55
Anyway I'm not hating, I said it was a good idea already and would be in if I didn't already have mine sorted (plus I suggested the Storm Motorwerks model... not sure if it was already settled upon beforehand though), it's just a little trivial to think/claim that if you just copy a shape then they're the same. Still, wouldn't mind a Z4 logo on mine
- Chris_D
Custom gear knob
Could be interested.
What surface texture/finish are you thinking about? Would be nice to have a bright or satin polish; 1P/2P or 1K/2K maybe....
You should be able to calculate weight if you're using solid edge.
Otherwise port to solidworks and do it that way.
Custom gear knob
Hi it will just be a standard turned finish, I thought about using scotch bright but I think straight off the lathe is better.Chris_D wrote: ↑Sat Mar 31, 2018 6:19 pm Could be interested.
What surface texture/finish are you thinking about? Would be nice to have a bright or stain polish; 1P/2P or 1K/2K maybe....
I thought the weight was shown highlighted in blue on my picture?
I only dabble in design or and tend to stay away from the physics.
If you have better use of the software I can send a STP file over and you could double check for me .
Hey, I went with the stormweks style because of your input.thanatu55 wrote: ↑Sat Mar 31, 2018 6:05 pm Anyway I'm not hating, I said it was a good idea already and would be in if I didn't already have mine sorted (plus I suggested the Storm Motorwerks model... not sure if it was already settled upon beforehand though), it's just a little trivial to think/claim that if you just copy a shape then they're the same. Still, wouldn't mind a Z4 logo on mine
I just don't have the time or the software capability to calculate the exact weight ratio.
I have a stubby gear knob and took the sizes from that.
If you have a vernier I could do with a OD measurementand the length.
And maybe the hole for the stick to go in
- Chris_D
Custom gear knob
AH see it - 605g. 100g heavier than the stormwerks knob I think (?)Buckley06 wrote: ↑Sat Mar 31, 2018 6:25 pmHi it will just be a standard turned finish, I thought about using scotch bright but I think straight off the lathe is better.Chris_D wrote: ↑Sat Mar 31, 2018 6:19 pm Could be interested.
Yep, sign me up plz.
Shoot me over the STEP file too plz. I'd like to run this through Rhino and V-ray to do some renders. Ta.
- thanatu55
Yeah I understand that, my apologies I wasn't trying to belittle anything you're doing I think it's a pretty awesome thing to do for the Zed community and a good price. I'd send you my gear knob if I could be sure I'd get it back quick enough but I'm heading to Australia next Saturday and I fear it's cutting it a bit fine (not that I'll need it in Australia!).Buckley06 wrote: ↑Sat Mar 31, 2018 6:39 pm Hey, I went with the stormweks style because of your input.
In fact, if it's helpful to you I'm prepared to send it to you to take whatever you need from it and give an alternate address to send it back to so I have it when I return?
Maybe you could lay it next to a ruler and take a few photos.
I should be able to get plenty of info from that.
Thank you for your kind gesture though.
Have fun in aus
Have fun in aus
- Davz
Perhaps you would care to explain the science?
- thanatu55
Not the most scientific approach but here you go
Depth:
Depth:
- thanatu55
- Davz
so how do you know there is science behind the design of a gearknob?
Please only make statements that you can quantify or it looks like you are belittling the efforts of a skilled and knowledgable engineer with no credentials of your own.
On the plus side, that was really good of you to take the photo's of your knob against the plastic rule....chapeau!
- thanatu55
"This shift knob is the result of extensive development, from its size and shape, to its weight. (Please scroll down).Davz wrote: ↑Sat Mar 31, 2018 8:12 pm so how do you know there is science behind the design of a gearknob?
CNC precision machined from Stainless Steel billet and fully optimised for an improved gear change. This is NOT the usual aftermarket gear knob - this is a fully engineered solution to improve your overall driving experience.
Weight
Weighing in at just over 500g, the stainless steel shift knob really does feel substantial. The "notchy" nature of the BMW gearboxes is significantly smoothed out with this weight through providing a greater pivot force, giving you an effortless and precise gear change every time. Prototyping revealed that with the shift knob too light - the notchiness would still be there, too heavy and gearchange would become laboured and sloppy. With the weight optimised, we have met both criteria - smooth and swift.
Size & Shape
The standard shift knob sits at an awkward height - for both ergonomic and aesthetic purposes. Our aim was to optimise the height for reduced throw and a more natural feel. Prototyping revealed that if it sat too low - users would grip the shifter with fingertips rather than the palm of the hand. This was more apparent with cars having centre arm-rests. Iteration resulted in an optimum height, correcting both aesthetic and ergonomic problems of the standard position. Furthermore, by merging a 2" sphere with a cone, every gear-change technique is accommodated for with an intuitive grip.
Short Shift Kits
This shift-knob is an ideal add-on to a factory or aftermarket short shift kit. Such kits increase the resistance during gearchange - amplifying the inherent notchiness but our shift knob allows you to have the benefits of your short shift kit without this extra resistance. "
Ahem.
Ahem.
