Custom gear knob
Discount codes and service & product offerings from forum members
Buckley06
Custom gear knob
Post by Buckley06 » Tue Apr 03, 2018 6:09 pm
Material has been ordered they had a off cut at 1600mm
For a extra £20 so I will make some stock.
Please check out my new project.
B06 gear knob and brake lever set.
viewtopic.php?f=13&t=109279
Chris_D
Custom gear knob
Post by Chris_D » Tue Apr 03, 2018 10:13 pm
Buckley06 wrote: Tue Apr 03, 2018 6:09 pm Material has been ordered they had a off cut at 1600mm
Nice one. Get cracking! :poke:
Received stp file. No chance to crank up rhino yet tho.
Buckley06
Custom gear knob
Post by Buckley06 » Tue Apr 03, 2018 10:36 pm
Chris_D wrote: Tue Apr 03, 2018 10:13 pm
It has to be delivered first.
I'm leaving yours till last :poke: :rofl:
nightyard
Custom gear knob
Post by nightyard » Wed Apr 04, 2018 5:43 pm
how large are these? Machine Monkey used to/might still make gear knobs but they aren't very large
Current : 640D M Sport & F30 320D
Previous: e39 3.0i, e86 3.0i, e85 3.0i, e46 m3, mk1 Audi TT, e92 2.0D
Buckley06
Custom gear knob
Post by Buckley06 » Wed Apr 04, 2018 5:55 pm
nightyard wrote: Wed Apr 04, 2018 5:43 pm how large are these? Machine Monkey used to/might still make gear knobs but they aren't very large
They are a similar spec to stormweks.
50mm od down to 25mm 75mm long.
Marlon
Custom gear knob
Post by Marlon » Wed Apr 04, 2018 7:27 pm
Moved to Forum Codes and Services as per Forum rules
Gone: 3.0si 2008 E85
911 997 Carrera S
Z4C_er
Custom gear knob
Post by Z4C_er » Wed Apr 04, 2018 10:46 pm
PM (query) sent Buckley.
2006.5 E86 Z4C si SE Phoenix Yellow
Chris_D
Custom gear knob
Post by Chris_D » Thu Apr 05, 2018 9:51 pm
Cranked up Rhino this evenin. First opportunity I've had. And of course all of my custom V-Ray profiles are borked!
Could only do renders via Rhino's basic built-in renderer unfortunately so a bit naff-looking.....
Also can't help but feel that it could do with being a bit.....fatter? Bigger radius at widest point on the X_Y axis perhaps. Just my own opinion tho. How does it compare to stormwerks knob in that respect?
Chris_D
Custom gear knob
Post by Chris_D » Thu Apr 05, 2018 10:04 pm
Chris_D
Custom gear knob
Post by Chris_D » Thu Apr 05, 2018 10:06 pm
Myah, best I could muster sadly.
Miffed re. V-Ray profiles. They took aaaaaages to program.
Used to use them back in ship-design days....
e94 006.jpg (92.9 KiB) Viewed 827 times
Buckley06
Custom gear knob
Post by Buckley06 » Thu Apr 05, 2018 11:55 pm
They look crisper than the phones I have :D .
Yeah the stormweks is 50mm on the XY OD.
Plus the material arrived today and I ordered 50 dia so that the biggest I can do.
I have loads of Acetal of your did want a bigger one. In navy blue, natural(white) and black.
Or grey PVC, green nylon.
Z4C_er
Custom gear knob
Post by Z4C_er » Wed Apr 11, 2018 6:01 am
Could anyone show me how this will assemble to the shaft?
The old one essentially clips on, that I know, but this one will use set screws; where does the gear shift boot go? How is it held in place and kept from sliding down?
Chris_D
Custom gear knob
Post by Chris_D » Wed Apr 11, 2018 10:04 am
Z4C_er wrote: Wed Apr 11, 2018 6:01 am Could anyone show me how this will assemble to the shaft?
Was wondering that too after looking at my knob yesterday :o
Not sure if Buckley is planning to provide a separate collar or sheath part that interfaces with the shift gaiter ring in order to keep it in place as you mention.
After playimg around with his cad model any collar would need to locate on the outside surface of the knob shaft as the clearance to fit something between knob and gear shaft is too small.
Buckley, care to elaborate? Any progress?
Buckley06
Custom gear knob
Post by Buckley06 » Thu Apr 12, 2018 9:27 am
Hi guy's,
Looking at my gear knob it's quite stubby and the bottom of the knob sits on top of the cover so no need to add anything.
I hope I'm on the right page as to what you are meaning.
Hmm
Progress I am looking to put them on the lathe today, my boss is over from France next month so need to work quick.
Will post a video on YouTube of them being made.
Z4C_er
Custom gear knob
Post by Z4C_er » Thu Apr 12, 2018 2:07 pm
Awesome.
