Intravee into cabin.
Hi. Is there a guide for getting the intravee from boot into the cabin in a Z4MC? I've had the rear firewall carpet off behind the seats, but can't plot any straightforward access through the compartment between the seats. Many thanks.
Re: Intravee into cabin.
Do you then feed the cable through from the cabin and it becomes visible from the boot? The cubby hole appears to be above the level of the cut-out for access to the cd changer in the metal bulkhead between the seats and boot.
Hmmm id have to go and check. I don't have a cd changer in mine. So I've have two cubby holes. One above the DVD nav unit and one below the nav unit. I drilled a hole in the one below. I Imagine that's where your cd changed sits.
Not sure how ur going to feed the wire through now, try using a coat hanger or something to pull it through perhaps?
I managed to avoid drilling a hole, really didn't fancy doing that.
With a bit of care you can just open the gap in the centre storage compartment (inside cabin) enough to pass the iPod connection through. I first fed some 3m number plate tape through the gap from cabbin into the boot. Used this to securely hold iPod connector end of lead. Then from inside the cabin withdrew the tape to the point when connector reached the gap. Then some firm put gentle constant pressure to just widden the gap enough for the connector to pass then relax, and the wire lead flows freely. So now iPod connected to this which lives permanently in the centre storage cubbyhole.
Hope that makes sense.
Much loved Z4MC
Thanks. Which gap do you mean. I've seen some mention of a gap above the cd changer and dvd nav and opening this up, but I can't see anything of the sort. It looks like a very snug fit already.
I'll double check and post a photo up. I'm stuck at work all weekend but will be home tomorrow if you can wait?
Much loved Z4MC
- barryb97
A good DIY here: http://www.billswebspace.com/bmwmc.htm
CDV del, clutch stp, LeatherZ console, strut bar, PB brakes, TC Kline coilovers, M3 reps, Stromung, Intravee II, paintd reflect, Hdlt wash disable, AS SSK, RTAB lmtrs, Vibra tech, BMW pedals, Skyer frnt. r lip, r defuser, coil cover, rad cover.
- barryb97
pics.
<a href="http://s1086.photobucket.com/albums/j44 ... C00816.jpg" target="_blank"><img src="http://i1086.photobucket.com/albums/j44 ... C00816.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1086.photobucket.com/albums/j44 ... C00812.jpg" target="_blank"><img src="http://i1086.photobucket.com/albums/j44 ... C00812.jpg" border="0" alt="Photobucket"></a>
as can see i was able to bring it through the gap between CD changer and cubby. Sits there nicely now, no compression on the cord once the connector is through
Much loved Z4MC
Thanks. I'll have another look when it warms up a bit!
Is there a guide for installing an Intravee if you have no CD-Changer? All the guides i seem to find are if you have a CD -Changer.
Actual situation on the car is OEM ipod interface and no Cd-Changer and want to add intravee interface.
- Stuart Truman
Your iPod interface is a replacement for a CD changer so you'll lose that if you fit an Intravee. You'd need both the Intravee and a KCA-420i for connecting to your iPod or iPhone. Very easy to fit and use though.
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
