How to replace rollbar covers
How-To articles are in here. Please use sub-forum for requests
Ale_72
Post by Ale_72 » Sat Jan 05, 2008 4:45 pm
Sorry again, always in italian :P
http://www.motortribe.it/community/foru ... hp?t=14837
BMW Z4 3.0i Steptronic
FlyOn20S
Re: How to replace rollbar covers
Post by FlyOn20S » Thu Jan 08, 2009 5:07 am
been trying to figure this out, thanks, can't read it but pictures do
ZetaTre
Post by ZetaTre » Thu Jan 08, 2009 7:30 am
Here's the tarnslation... I take NO credit for this, I'm just translating it...
First, cover the paint of your Z with a cloth or something similar
Find the cover of the seat belt roller and remove it. It's held in place by pressure, and can be removed with a simple move. [looks like it needs to be pulled up and backward]
By moving the seat belt you'll gain access to a Torx screw: unscrew it and and remove the plastic seat belt guide.
With the help of some wood wedge (do not use a screw driver because it's very easy to ruin the plastic cover [if you check with Harbor Freight Tools, BavAuto or auto supply store they have nylon coated tools used to remove door panels and such]) try to open the latches holding the roll bar covers
A detail of the latch...
At the first try with the right cover, I broke two latches, but it's not a big deal...
Once you remove the rear cover, we can use a screw driver as a lever to remove the front cover. Use these holes...
The rollbar will look like this:
At this point, drill the plastic covering the rollbar to place the guides by the holes already on the rollbar. Before closing up everything remember to place the inner part of the wind breaker...
Once you're done, close everything up!
[if you buy the BMW wind braker, ask for the installation instructions: parts must give them to you]
2003 Z4 2.5i
2004 X3 3.0i
2002 Ducati Monster S4
Ale_72
Post by Ale_72 » Thu Jan 08, 2009 8:04 am
Great job!
I'm always to lazy to translate :thumbsup:
ZetaTre
Post by ZetaTre » Thu Jan 08, 2009 8:11 am
I'll probably be back in Milan around Easter... I'm from Sondrio...
2003 Z4 2.5i
2004 X3 3.0i
Ale_72
Post by Ale_72 » Thu Jan 08, 2009 8:19 am
ZetaTre wrote:I'll probably be back in Milan
I do not know if I'll be in Milan or somewhere else in Europe (because of my job) but when it happens to you to be around just let me know, if you want, we can have a few beers.
