Changing Rear Lights
How-To articles are in here. Please use sub-forum for requests
peddy
Post by peddy » Mon Jan 18, 2010 3:12 pm
Hi,
I have a set of clear ones and was planning to replace them with my amber ones. Anyone got a how to? I couldn't find anything on the forum.
Thanks!
gannet
Re: Changing Rear Lights
Post by gannet » Mon Jan 18, 2010 3:14 pm
not really any need - its quite simple...
just remove the cover then undo the retaining bolts and they pop out :thumbsup:
-- Gannet.
Current: MINI JCW... - Modification: Driver Upgraded :D
Previous: DS3 DSport, Z4 3.0SE, 206 GTi & XS, Alfa 147 Lusso
Rudd
Post by Rudd » Mon Jan 18, 2010 3:15 pm
hi peddy what do you mean? you have lights with clear indicators and you want amber ones?
EDIT: of you need to swap the whole light i have a set of amber ones sitting in the house in perfect condition with bulbs. id swap u if you want??
peddy
Post by peddy » Mon Jan 18, 2010 3:45 pm
Rudd_2002 wrote:hi peddy what do you mean? you have lights with clear indicators and you want amber ones?
No, my car has the "lovely" amber ones already and I wan't to swap them with clear one.
Gannet, thanks.
Rudd
Post by Rudd » Mon Jan 18, 2010 3:47 pm
just 3 bolts and a cable, easy. just be careful you dont knock them out onto the floor when you are taking your current ones out :thumbsup:
have you got a clear centre light aswell?
gannet
Post by gannet » Mon Jan 18, 2010 3:50 pm
tricky bit is moving the 'french fry' over to the new ones. It is just stuck on with tape so can be prised off carefully.
get some new tape and easy enough to put on the new set :D
I forgot about the lighting cable...
-- Gannet.
Rudd
Post by Rudd » Mon Jan 18, 2010 3:58 pm
i left the frenchfry off when i changed mine and i like it. the back of the zed is a little complicated and it makes it more simple.
peddy
Post by peddy » Mon Jan 18, 2010 4:45 pm
Rudd_2002 wrote:have you got a clear centre light aswell?
Yep! Got that too.
Rudd
Post by Rudd » Mon Jan 18, 2010 4:59 pm
nice one, make sure you dont overtighten it! on mine i just turned the nuts with my fingers as much as i could then give it one turn with a socket and thats enough to keep it in.
the reason some break is because the springs are overtightened. :thumbsup:
sorry if im telling you how to suck eggs :P
Rudd
Post by Rudd » Tue Jan 19, 2010 10:40 am
hey peddy, how did the change go. u like it?
i think it brightens up the back really well. pics pics pics :thumbsup:
