Ben. wrote:Shipkiller wrote:Once you get the wheels off, you will find that the breaks are a great design. Easy pad replacement.Ben. wrote:We dont have any Brake Replacement "How Too's"
I'm sure I will manage fine to do the disks and pads without touching the hydraulic system.
Anything I should be warned about?
Ben,
The only gotcha would be watch that you don't snap your 'brake wear indicator wires'. They are designed to wear through and ground out and light the brake light. If yours are in good shape, just reuse them.
Mine were on the left front and right rear...
If you have to replace them, I have seen them on the web for about $15.00 each. Not sure what the stealer charges.....
