Run flats to non-run flats
seg101
Post by seg101 » Fri Apr 21, 2017 10:08 am
Hi all,
I've had my 2005 3.0 Z4 for 2 years now and have been running the Bridgestone run-flats that were fitted when I bought it. The front tires are now showing signs of wear so I'm considering replacing them with Goodyear Eagle F1s.
My question is, when moving from run-flats to non-run flats, do I need to replace ALL FOUR tires at the same time or am I ok just replacing the front two and then completing the switch when the rear's are ready to be replaced.
Thanks!
csm180
Post by csm180 » Fri Apr 21, 2017 12:40 pm
Hi I believe you can run two the same on one axel, i.e. Two on the front or two on the back. You mustn't mix on the same axel, so replacing the fronts to non run flat is fine. I have never done it as when I moved to nrf all were changed. I really rated the uniroyal rainsport 3's as an alternative.
E89 23i pearl black.
E85 Titanium Silver 3.0se sold
warmasice
Post by warmasice » Fri Apr 21, 2017 12:52 pm
Rainsports are REALLY good, especially in our climate. If you're in the UK that is.
Neilc
Post by Neilc » Fri Apr 21, 2017 1:00 pm
I've just ordered some Yokohama V701's better ratings than the good years and a bit cheaper.
2.5Si Stirling grey Z4, green induction kit, front & rear strut brace, clear third brake light, stubby ariel, 19" rims, eibach pro springs and colour coded duck tail spoiler.
Who is online
Users browsing this forum: rally-chris and 11 guests
