Centre front jacking point
- pvr
Re: Centre front jacking point
Copyright Ron Stygar
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- -Tom-
And there definitely isn't a hockey-puck for the facelift (non-m) oops
Sent from my Nexus 5 using Tapatalk
-Z4 M Coupe, Silver Grey, Imola Red Nappa, carbon leather, CSLs, SuperSprint Race, Track Mode Enabled
-Tesla M3 LR
Previous - 3.0 si sport roadster, Silver Grey with Oregon Pearl Grey leather, Piano black, EIbach Pro, Stubby
-Tesla M3 LR
- Bing
That is definitely not on my facelift car, as it looks to be part of the reinforcement plate that I need to replace. I have a spare one waiting to go on in the garage and it doesn't have the jacking point. It also doesn't have the air vent at the right of the picture, so obviously a part unique to the M.
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- stupot67
Just had a look under mine - where the jacking point is indicated on TIS there's a shallow recess about the size of the side jacking points. The point is I can't see what and in that case how close there is anything behind it, but as Tom's already used it ...... What could possibly go wrong .
Stu.
Stu.
- Bing
To be honest, jacking one side, sticking an axle stand under, then jacking the other side...will take you about 5mins more than trying to use a jacking point that's not there... And will avoid risking buggering up the front axle.
- -Tom-
I might have been foolishly lucky Stu. Might be worth jacking from the side points at the rear high enough to get a front axle stand under first and work your way round.stupot67 wrote:Just had a look under mine - where the jacking point is indicated on TIS there's a shallow recess about the size of the side jacking points. The point is I can't see what and in that case how close there is anything behind it, but as Tom's already used it ...... What could possibly go wrong .
Stu.
-Tesla M3 LR
-Tesla M3 LR
- stupot67
A bit of an update....
I lifted the car via the sill jack points onto axle stands, then removed alloy under tray (Replacing TCA's and bushes, CDV removed and changing gearbox oil).
On closer inspection the front subframe is strengthened along it's length internally to the box section and the center point is drilled and tapped to accept a jacking point (As per M's) I assume.
I lifted the car off the axle stands via the subframe while watching very carefully, absolutely no deflection. From this I would say that TIS is correct, and for facelift's this is a viable center jacking point....But only for facelifts.
Stu.
Stu.
- -Tom-
Good update Stu. I had come across this somewhere as we mentioned as being facelift and m/ specific. I also saw no movement whatsoever on jacking.
Probably worth adding that anybody who may come across this and goes by it does it entirely at their own risk due to so many conflicting write ups on the topic
Sent from my Nexus 7 using Tapatalk
-Tesla M3 LR
-Tesla M3 LR
- chutley
Is there a definitive answer for this yet? I have the facelift 3.0Si and there is an alloy recess in the centre that looks like a jack point... Is there anything underneath it to support the weight, or is it a red herring?
If not, how do you jack up the front of the car...? If you use the front jack point under the door sill, where can you then place the axle stand?
Good question I have been wondering the same although mine is a lowly 2.0 4potchutley wrote: ↑Thu Feb 21, 2019 3:52 pm Is there a definitive answer for this yet? I have the facelift 3.0Si and there is an alloy recess in the centre that looks like a jack point... Is there anything underneath it to support the weight, or is it a red herring?
- chutley
viewtopic.php?t=20640
I've found this thread, which shows the point I refer to, but no definitive answer.
