Another new guy
Another new guy
Purchased a e85 z4 .2.5 with 54k on the clock.
Any suggestions on what to do first?- mr.tourette
Another new guy
get better pics up? Congratulations on the new zed
- colb
Another new guy
Get a good code reader plugged in and check for any set codes and any shadow codes that come up, the shadow codes will let you see what has gone on in the past.
Give the car a good service, engine oil and filter, gearbox fluid change and Diff fluid change, having done all that you know whats in it.
Take the spark plugs out and inspect clean and gap them if they look ok otherwise put a set of new ones in, keep old ones as spares.
Prior to servicing it is a good idea to visually check over the entire engine for any signs of oil leaks, usual places are Cam Cover gasket and the oil filter housing to engine block joint. Both will eventually fail through age and repeated heat cycles hardening the gaskets.
Check all rubber vaccum hoses and inlet boots for cracks and holes, replace any that are found, air leaks are the common cause for bad running and messing up the fuel trims. Once you sorted all that out turn attention to checking out condition of the brake lines and hoses, any suspect ones should be replaced. Pull the brake pads and check them out, clean and replace if the pads have life left in them. Change of brake fluid might be worth doing if you have no recent history of it being done in the last 2 years.
Update your user details or add a Signature with your location, it helps if someone is near to you who may be able to give you a hand with jobs on the car when needed.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- sars
Another new guy
Hello and welcome, where are you based?
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
- buzyg
- Mr Tidy
Another new guy
Hi and welcome to the forum.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- enuff_zed
Another new guy
Very nice! welcome aboard.
I'd start by removing the clipboard that's got caught up in the front bumper.
Another new guy
Thanks for all the useful insightscolb wrote: ↑Sat Sep 11, 2021 5:14 pm Get a good code reader plugged in and check for any set codes and any shadow codes that come up, the shadow codes will let you see what has gone on in the past.
- Ole gits rule
Another new guy
Hello and welcome to the forum
M4 Vert in Yas Marina Blue
