Z4 Newbie, 2.5 Si Sport in Black with red leather
Gjm91
Post by Gjm91 » Mon Mar 11, 2019 9:46 pm
GixerWill wrote: Mon Mar 11, 2019 9:33 pm
Gjm91 wrote: Mon Mar 11, 2019 8:13 pm
GixerWill wrote: Sat Mar 09, 2019 11:47 am Hi, thanks for the advice.
I have just looked over the "How To", regarding drilling the fogs. I think I'll give it a go.
Although I just discovered the following:
Eurocarparts have a 35% off promotion using code WINTER35
Links to both lights:
https://www.eurocarparts.com/ecp/p/car- ... 0&0&000469
https://www.eurocarparts.com/ecp/c/BMW_ ... 050&000469
Brings the cost from £245 to £159, with Free Same Day delivery.
:D
Pics coming soon.
Welcome - got my replacement fogs from carparts4less - worked out about £69 each - they still seem to be selling at that price with the current discount code which is a bit of a bargin. :thumbsup: enjoy the zed
Thanks Gjm91. It turns out carparts4less do still have their winter code of "WINTER12" available. New Total = £137...You sir just saved me £22. Thanks :D
no worries gixerwill :thumbsup: - mine also came with bulbs fitted so no need to buy another set ( had already bought another set thinking i would need bulbs too ) :headbang:
E89 2.0 i S Drive M Sport
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
GixerWill
Post by GixerWill » Wed Mar 13, 2019 10:32 pm
Thanks for the heads up Gjm91, I would have most likey done the same tbh.
GixerWill
Post by GixerWill » Fri Mar 15, 2019 1:55 am
Hi Guys
I thought I would update my thread. I didn’t want to clutter the place up with constant new threads with every minor change I make to the car. So thought my first forum post may be the best place to keep everything together. I have made a few changes.
1. My oil leak has been taken care of :D
2. I have drilled three 4mm holes in the underside of the fog lights, to hopefully drain the water away. I would post a picture of this, but the fogs are so bad you can’t see the holes. Hopefully in a few days I will be able to add some pics where the holes are visible.
3. I swapped out the OEM aerial for the below: https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
OEM Aerial.jpg (170.79 KiB) Viewed 829 times
GixerWill
Post by GixerWill » Fri Mar 15, 2019 1:58 am
4. I changed the number plate lights. The OEM lights were fine, but just not quite white enough: https://www.ebay.co.uk/itm/BMW-LED-Lice ... 2749.l2649
Sorry, but I forgot to get a shot of the OEM bulbs. :oops:
So far, all pictures taken of the car are on a SGS8. So, not the best. The above night shots do not do the lights justice. They are super bright, almost too bright.
GixerWill
Post by GixerWill » Fri Mar 15, 2019 2:10 am
Changed the badly corroded wiper blades to the below:
Heads up though, the passenger side 20" is too long and does not make full contact on the glass when in the down position.
I have yet to test these at motorway speeds.
https://www.wiperblades.co.uk/bosch-sp2 ... iper-blade
I also changed the sticky Parrot Control Pad for the cars MKi9100. It appeared someone had spilled something on it, quite disgusting.
https://www.amazon.co.uk/dp/B003TJTLUY? ... E_DDE_dt_1
Now it's working like new. I am able to stream from Spotify with this and the reception is spot on. :D
Time for that well needed detail. Weather permitting.
GixerWill
Post by GixerWill » Fri Mar 22, 2019 12:07 am
Next up was to try and restore the headlights.
I used the Autoglym headlight restoration kit.
Fairly happy with that result for £20. Just a shame about all those stone chips :headbang:
Mr Tidy
Post by Mr Tidy » Fri Mar 22, 2019 11:03 pm
GixerWill wrote: Fri Mar 15, 2019 2:10 am Heads up though, the passenger side 20" is too long and does not make full contact on the glass when in the down position.
I think that's normal - every pair of blades I've fitted to my Z4 so far has the same issue! But at least it means it clears the top part of the screen on the passenger side. :lol:
I drilled 3 holes in my fog-lights last year, and within a couple of months they were clear so hopefully it will work for you too!
Your headlights certainly look better. :thumbsup:
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
GixerWill
Post by GixerWill » Sat Mar 23, 2019 1:24 am
Mr Tidy wrote: Fri Mar 22, 2019 11:03 pm
ThanksMr Tidy. The fogs have already started to clear, a little. Hopefully as the weather improves it will help. I try and use them as often as I can.
Cheers for the heads up regarding the wipers :thumbsup:
Thanks, the headlights look much better in person, the camera did not pick-up on how bad they were originally.
