Plastic Strip Under Nose.
blurryface
Post by blurryface » Mon Sep 03, 2018 3:30 pm
Hi there,
Does anyone know what the plastic strip bolted under the nose below the radiator is called? I've torn mine on a kerb and haven't managed to find a replacement. Not knowing what it's called isn't helping :|
Cheers,
Z4 plastic strip.rtfd.zip
(648.59 KiB) Downloaded 32 times
rally-chris
Post by rally-chris » Mon Sep 03, 2018 4:12 pm
I can't work out what the part is you mean - I suggest you find it on realoem.com to get the part number and then simply order it from your nearest BMW dealer if a google search doesn't bring one up cheaper from somewhere else.
08 Z4 3.0si Sport Coupe in Montego Blue
blurryface
Post by blurryface » Fri Sep 14, 2018 1:41 pm
Hi Chris,
Thanks for your reply. If you look under the nose, it's the curved black plastic strip directly under the radiator held in place with 4 bolts.
I've looked on RealOEM and it's not listed.
