Hi all.
I'm looking to modify my 3.0si z4 but want to start on the brakes first - any reccomendations on the cheapest most effective way to do this.
E85 z4 brake upgrades
- markplant
Maybe start with stainless brake flexi pipes to replace the rubber ones , an a brake flush ,
- Z4 Gaz
A decent set of discs and pads will suffice unless you are going to be tracking the car.
As standard the fronts are 325mm, which is more than big enough for a car of this weight for road use.
E85 3.0i
This.
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure (should have done it at 100k)
- ph001
I’d leave the discs and lines as they are and just upgrade the pads. Performance Friction carbon metallics for the win
Only advice I can give is don't delay if they need doing. Just replaced mine the day before some idiot decided to do a right turn across me, needed all the brakes I cud find to miss him. I was doing 50 mph speed limit at the time. Quick pant change was needed afterwards.
As said,the the 3.0 Si had bigger discs than earlier 3.0i......
Start with Performance pads,and a decent set of grooved/slotted discs and braided brake lines if you want to go further.
EBC are well priced,or Brembo for not much more.
Interlagos Blue M RDSTR,2008. Logic7 dsp Hifi;satnav,stubby,htd seats,etc,etc.
Black 2005 3.0i NOW SOLD(and missed)
- shuey
Just bought a new set of front Brembo grooved front rotors and pads, waiting to install this week. 210 with sensors from carparts4less, decent price for Brembo a I think. I use to buy ebc for my 350z, but they double the price of Brembos
M2 OG / Manual / Grey
Previous
Z4C Si Sport / Manual / Alpine White
350Z VQ35DE / Manual / Silver
Seat Leon Cupra MKII / Manual / Silver
Ford Puma 1.7
Rover 214 Si (I know!)
Previous
Ford Puma 1.7
- paulc_bkk
Lots of good advice and sensible suggestions here
I upgraded my brakes a while ago using part of a kit I had for my E36 but sold the car before I had chance to fit them.
Porsche Boxster S calipers with E46M3 CSL discs and fitting kit, matched with standard E85 3.0 rear calipers and vented discs
I know it’s a bit over the top, but considering I had the parts laying around it made sense to do it. If I hadn’t already got the Porsche calipers I would’ve gone with the 3.0 front setup with good pads
