Oil leak
Oil leak
Had smoke coming out of engine. RAC guy diagnosed small oil leak from head gasket. Says will need head taking off to fix and new timing chain after thats done. Alternatively he said just run it as oil will burn off and will be an expensive job. Anyone able to help re similar experience/solution please?
Oil leak
The rocker cover gaskets are well know failure points on these engines, which not at all the same as a head gasket leak.
Cheap and easy fix.
Oil weeps from the top cam/rocker gasket and runs down, causing oil smoke and oil burning smells.
Check it out before going HG route.
Cheap and easy fix.
- Chris_D
Oil leak
+1 cam cover gasket. They all go eventually!
Check the oil filter housing gasket too.
Worst case is main seal between engine and gearbox.
Sump gasket can leak too.
Worth poking around...
