New Coupe owner
- Silverzedtom
New Coupe owner
Looks great
The wing mirror glass will 100% fall off very soon if you don’t pull it off and glue it on with something decent. They only get a tiny blob in the factory, Ive done both of mine now. Somehow one of mine fell onto the tarmac at 30 odd mph and survived...
What are you thinking with the audio? I’m also looking to do something with mine.
E85 2.5si
F55 Cooper S
F55 Cooper S
New Coupe owner
Beautiful car there, looks awesome as it is now. love the grey colour. I have a titanium silver Coupe and kinda wished I'd gone grey. Wheels look great in matching grey too. Stubby is a Peugeot part though mine was already done when I got it so couldn't say which. The lines on the coupe stand the test of time. I find the new Jag F-type not too disimmilar. Anyway, I'm rambling, welcome on board!
3.0si Coupe, Titanium Silver, manual, nearly all of the trimmings.
New Coupe owner
Hi and welcome.
Great looking car.
Great looking car.
- tee.gilding
New Coupe owner
I know what you mean by the options, but even still it was a pretty basic spec. However, I kind of like that: I get to focus more on the driving and less on the gadgets!Mr Tidy wrote: ↑Tue Jun 12, 2018 8:42 pm Glad you finally found one OP - and it looks great.
It may not be as basic as you think! Z4s didn't get a lot of features that were standard on even 1 and 3 series models, like those optional rear parking sensors I can see in one of your photos!
Mine had the sluggish starter motor you've mentioned when I got it - when I had it serviced my BMW Indy said it can be the starter motor, but mine needed a new battery last December and it's been much better since then (thankfully). My Indy supplied and fitted an OEM battery for £90 + VAT (he says they are Exide - well the cars were built in the USA).
I'm not sure about the wing mirror - I think the glass is a push fit so maybe one of the clips has broken?
Not sure why you'd want a stubby. My radio works much better since I went back to a whippy! But if you still want one I've got one of the Peugeot/Citroen ones I'll post to you if you pm me with your name and address.
When you mention 19s and decent rubber I hope that means non-runflats!
Here's a photo of mine with the stubby on it:-
19s and proper rubber. I think I've found the right wheels, just need to find the right tyres next.
How badly does the stubby affect radio reception??
2007 Z4 3.0si Sport (E86) : Stratus Grey : Black Oregon leather : 19" Veemann V-FS33 : BC Racing coilovers : Kumho Ecsta rubber : MTEC discs : Brembo pads : stubby aerial : ZHP gear knob
Instagram: @stratus.z4coupe
- tee.gilding
New Coupe owner
I'll have to get the glass sorted asap then. Can I use double-sided tape or is glue the only way?Silverzedtom wrote: ↑Tue Jun 12, 2018 8:53 pm The wing mirror glass will 100% fall off very soon if you don’t pull it off and glue it on with something decent. They only get a tiny blob in the factory, Ive done both of mine now. Somehow one of mine fell onto the tarmac at 30 odd mph and survived...
In regards to audio, I'm thinking of starting with a head unit upgrade, and then I'll look to adding a set of subs behind the seats. Not sure though, might replace all the speakers with better quality ones as well.
- Silverzedtom
New Coupe owner
Sounds good - you’ll have to let us all know what you end up doing...tee.gilding wrote: ↑Wed Jun 13, 2018 6:37 amI'll have to get the glass sorted asap then. Can I use double-sided tape or is glue the only way?Silverzedtom wrote: ↑Tue Jun 12, 2018 8:53 pm The wing mirror glass will 100% fall off very soon if you don’t pull it off and glue it on with something decent. They only get a tiny blob in the factory, Ive done both of mine now. Somehow one of mine fell onto the tarmac at 30 odd mph and survived...
I think tape would end up looking a bit naff as the glass sits inside a very small lip around the edge of the backing. I used gorilla glue extra strong and clamped lightly over night. One of them has been on for around a year and still feels rock solid. I’m not sure how well it would heat with tape as well.
The mirrors are heated whenever the car is on which won’t have helped the original glue over time. You could always pull a fuse to stop them coming on over the summer months.
E85 2.5si
F55 Cooper S
F55 Cooper S
- tee.gilding
New Coupe owner
How do you get the glass off?Silverzedtom wrote: ↑Wed Jun 13, 2018 10:54 am
- Flyingfifer
New Coupe owner
Welcome to the Forum always good to have another member of the Executive Coupe Club
Get that wippy off
Get that wippy off
2006 3.0Si Coupé in Monaco Blau with all the optional trimmings
- Flyingfifer
New Coupe owner
This has happened to both my mirrors (possibly due to the heating element weakening the glue) the mirror itself is mounted on a heating element which is in turn mounted to a plastic plate with a twist fit/lock mechanism. If you aim the mirror to the lowest outside point you should be able to get a flat head screw driver in at the top of the mirror to slide open the lock, this will turn and the plate will come loose easily. Personally I have used superglue to secure the glass to the heating element and it worked a charm. If you leave it too long the glass will fall out, if this happens a stealer will charge you crazy money for a new mirror (they only sell the whole thing, mirror, heating element, mounting plate) If memory serves its about £60tee.gilding wrote: ↑Tue Jun 12, 2018 7:38 am The passenger side wing mirror glass is loose - is that an easy fix?
I ordered a replacement mirror, with element and mounting plate however its a replica so its not perfect and its a push lock rather than a rotary lock so getting it back off will be a nightmare
- tee.gilding
New Coupe owner
@Flyingfifer thanks I'll give that a go. I'd rather not have it come off! Survived the drive from Wales back home, wobbling all the way back. Glad it didn't fall off and disappear somewhere on the A34!
And yes the whippy will be removed. I've been informed they're not actually required for FM radio, only AM. If this is true, I may try work out a way to a delete...
- Mr Tidy
New Coupe owner
Yes, I had read that too but mine still gets better FM reception with the whippy than the stubby!tee.gilding wrote: ↑Wed Jun 13, 2018 1:18 pm And yes the whippy will be removed. I've been informed they're not actually required for FM radio, only AM. If this is true, I may try work out a way to a delete...
Maybe just take the whippy off and see what reception you get with no aerial first.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Attilio
New Coupe owner
Welcome to the fraternity of Z4s with a proper roof
Very nice car, congratulations!
Z4M Coupe, Interlagos blue, black leather, piano black, stubby, OEM CSLs, evolve intake, cup holders...pretty much stock
2019 Toyota Corolla hybrid 2.0L - new daily drive
- tee.gilding
New Coupe owner
So it turns out the wing mirror glass had been stuck on with blutack! Wtf?!
Do I glue the glass back onto the black pad that's in behind it? Will 5-minute epoxy be too harsh??
- z4pilot
New Coupe owner
Yes - that's the heating pad. I used some glue that advertised itself as temperature resistant when I did mine. I packed some cardboard onto the glass and used masking tape to keep the pressure on whilst it dried overnight. Not had any issues since.
Now Gone - 2008 Coupe, Montego Blue, Champagne leather and Piano Black interior, Eibachs & Koni Sport shocks, Style 230 19s, Eisenmann Quad - approaching perfection...
- mr wilks
New Coupe owner
Or you can apply the adhesive & fold the unit in / up so the mirror won't fall out
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
