Finding blue tooth module on z4 2003
GuidoK
Post by GuidoK » Thu Feb 08, 2018 4:21 pm
ph001 wrote: Thu Feb 08, 2018 3:14 pm I couldn't even find the right menu to get to it in INPA, maybe |I have an older version software. It said it couldn't find the ECU when I tried to go into telephone menu.
Maybe you dont have the right data files in INPA. I dont think my INPA install is complete too but I hardly use it because I use ISTA-D. For that you need to have a specific version of the BMW standard tools/ediabas and the INPA version included in that is the one I use if I have to.
But I had no problem connecting with the ULF. And I tested the bluetooth activation, and indeed you can connect to that when activated with your phone.
Select the telephone module in communications:
Select activate (F6)
In the next menu select BT SEARCH (F5) and the car goes into BT pairing mode:
The only think I couldnt find is a way to remove all previous BT connections via INPA.
But as you're in BT pairing mode now you can hold the BT button on the center console for 10 seconds to remove the previous connections (after 10 sec. you hear 3 beeps as confirmation that the stored connections are deleted)
ph001
Post by ph001 » Thu Feb 08, 2018 4:27 pm
Thanks so much for taking the time to do that - you are a real credit to the forum. I'm fairly sure when I selected 'telephone' option last time it came back with a 'can't find ECU' error. Strange as most other things like live data / diagnostics work fine. I will check software version tonight and have another go. :thumbsup:
ph001
Post by ph001 » Sat Feb 10, 2018 2:50 pm
OK, so this is the problem I have when I try to select Telephone from the menu in INPA...
In fact I get the same error when I try to access any of the options in the communication menu. INPA works otherwise though (i.e. can read all engine parameters / DTC's etc)
This is the lead I am using...
