Hello from new member and owner
Hi, Just purchased my first Z4 2.0 sport. Really pleased and enjoyed first spin over the weekend. However gutted that I did not pick up on a very small flaw in the roof. It's only about 6mm round and does not go through the roof, so no leaks but would like to fix before it gets worst. Just been phoning around a few roof specialists today and been told to replace. Seems a costly option for what I would have thought is a minor repair. Prepared to travel to find someone from home in Crawley, West Sussex
- RickRob
Hi and welcome.
Sorry I cannot help re the roof, but a pic of the damage on the roof may help others comment. Whilst you have your camera out take and post a few of the whole car!
Good luck
Good luck
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
- metal licker
Hi and welcome to the forum
Sorry can't help with the problem
718 4.0 GTS Boxster in YELLOW
718 Guards Red Boxster .........Gone!
A35 AMG saloon .........Gone!
JCW ...........Gone !
E89 35i Msport VO ................Gone !
E89 23i SE DSB ................Gone !
Hello to Jason Isaacs
Welcome to the forum, did someone mention photos
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Mr Tidy
Welcome to the forum OP.
I hope you can get your roof sorted - and don't forget some photos!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Many thanks for your kind words. As you can tell by the material very small damage but would like to get fixed
- Swiftly
Quite a common problem and is usually caused by the roof material over time touching and rubbing against the rubber shuttle, I had similar happen on mine and used this product to repair mine.afeldmanis wrote: ↑Mon Jan 15, 2018 10:33 pm15160517529492010962061.jpg Many thanks for your kind words. As you can tell by the material very small damage but would like to get fixed
https://z4-forum.com/forum/viewtopic.ph ... 8957&hilit
- MrPT
Beat me to it! I never asked you how your repair went, Swiftly, so trust it went ok then?
I found it to be quite fiddly stuff but extremely durable. Would have loved to have figured out the correct way to texture the surface, but only had the one shot at it and failed! Must be hundreds of people with the same issue - I sometimes notice it on Z4s in car parks.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Swiftly
The product is very flexible and it went on very well MrPT. Repair was still holding over 2 years later when I sold my zed, so I can highly recommend the product.MrPT wrote: ↑Mon Jan 15, 2018 11:09 pmBeat me to it! I never asked you how your repair went, Swiftly, so trust it went ok then?
- Marlon
Welcome to the forum. Replacing the roof seems like overkill !
The above product must surely be your first step.
Gone: 3.0si 2008 E85
911 997 Carrera S
We need photos of the whole car
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- buzyg
Welcome to the forum. I bought some of that vinyl repair and used it on our inflatable kayaks, It's very tough and flexible stuff.
This is brilliant and I will of course give this a go. Got it in my my mind to tape a washer to the roof to stop overflow and then then perhaps use a scalpel to gently run along the contors of the vinyl while solution is setting. We'll that's the plan. Unfortunately can't take pictures of car as wedged against my son's car and he's still in bed, but will do later.The trimming companies that I spoke to must know about this product being in the profession so about annoying that that the advise given is to replace. Thank you all so much in your support here, really appreciated.
- Crazy Harry
Hi and welcome - on a 'man math' type practical approach the damage doesn't matter - you bought a roadster you'll have the top down all the time
- piotrZ4
