Test
Test
Just click on the ad files at the bottom lhs
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- N4LLY
- Mr Tidy
Test
Well if your signature is a link to your Google photos then it is showing, but sadly it doesn't work.
Error 404 - "The requested URL was not found on this server".
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Jembo
Test
Yes... it’s not very obvious n easy.
I found a thread in search that I followed that sends u to some pic compressing website... good luck
Lifer 54
Lifer 54
- IAmOrion
Test
You need to wrap your image in img tags...
Code: Select all
[img] IMAGE URL HERE [/img]
Example:
[img]http://imgshare.iamorion.co.uk/images/af890aafe530618c05aa190168550274.png[/img]
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
- N4LLY
Test
I get this...IAmOrion wrote: ↑Mon Jul 15, 2019 2:44 am You need to wrap your image in img tags...
Code: Select all
[img] IMAGE URL HERE [/img] Example: [img]http://imgshare.iamorion.co.uk/images/af890aafe530618c05aa190168550274.png[/img]
"It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct."
- IAmOrion
Test
Have you double checked the URL is correct? The one in your signature at the moment goes to a google 404 (missing/not found) page
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
