2003 z4 2.5
Gary busta Head
2003 z4 2.5
Post by Gary busta Head » Wed Jul 21, 2021 5:45 pm
Hi need some advice before taking hammer to my z4 😊I’ll try and explain as best I can. Drive to holiday destination and had a few Warner lights come on but checked and all way good the more I drove the more came on but was a perfect driver and made it back 400 miles without fault. Local garage found Abs sensor and oil pick up sensor issues so change them. Drove great again 15-20 miles when stopped ticking over warning lights back on and engine starting revving up and down. Back to the shop this time fuel rail issue new one 😊 then before I collected it alternator issue, picked it up 10 miles same again when standing still, the garage then diagnosed Ecu over heating so we went for new Ecu which was the programmed to car by BMW specialist. Seemed all good sat on MOT ramp and boom gone again garage don’t want to play anymore and I’ve spent a bloody fortune😑 Any help or a box of matches would be great . Tks
zriha
2003 z4 2.5
Post by zriha » Wed Jul 21, 2021 6:14 pm
Hm, sorry to hear that mate, a lot of problems, seems to me not all connected, but as you are talking about sensors (yeah, they can die), what is the milage of the car?
So, to conclude, you have:
- new ABS sensor
- new OIL pick up sensor
- new ECU
And the problem continues? Hm, I am not a mechanic or car specialist, but I finished technical school for electronics, and I reckon, you have a voltage/power issue - bad wire, bad battery, a bad connection from battery to the engine, as all those symptoms can be related to that from my experience.
Maybe someone had a similar or the same issue, I didn't and I have 2003. 2.5 z4 with 201.000 km on the clock.
Current fleet
BMW Z4 (E85) 2.5i 5-speed manual
Mini One R50 1.6 Lohen L01
Piaggio Vespa GT200L
enuff_zed
2003 z4 2.5
Post by enuff_zed » Wed Jul 21, 2021 7:25 pm
Welcome to the forum, sorry it's in such circumstances.
I'm sure I won't be the last to say that before you do anything else, how old is the battery. They throw up all sorts of issues on these cars.
E89 20i SDrive M Sport - Valencia Orange
E85 2.5i - Sterling Grey - Better half's fun car
E85 2.2i - Sapphire Black - Project Do-er-Up-er
Online
Mr Tidy
2003 z4 2.5
Post by Mr Tidy » Wed Jul 21, 2021 7:58 pm
Hi and welcome to the forum, although I'm sorry to hear your car is giving you such a hard time. :(
As suggested dying batteries on these can throw up all sorts of electrical issues - mine did when my battery died earlier this year.
If that isn't the problem you need to get the faults codes read via the OBD port and go from there, ideally by a good Independent BMW Specialist.
I could send you some matches, but I hope you can find a solution. :thumbsup:
Coupes because stunning!
Current - Silver Grey MC, Imola Red heated Nappa & carbon trim. Aeros, H & R Coil-overs, 224s, Strut brace, Nav, cup-holders, DSP Hi-Fi, pdc, cruise, MFSW, no CDV! E90 330i daily
Gone - Montego Blue
Gone - Ruby Black
Ole gits rule
2003 z4 2.5
Post by Ole gits rule » Wed Jul 21, 2021 8:25 pm
Battery is where I would start based on multiple electrical problems
2011 23i M Sport Highline in Alpine White with Smart Top installed
Is Mr whippy staying - you bet your arse it is :P
1000rr
2003 z4 2.5
Post by 1000rr » Wed Jul 21, 2021 8:28 pm
Unplug the MAF and see how you get on. :thumbsup:
Sterling 3.0, Bentley burgundy leather, Aeros..
Ducati Supersport S
Gary busta Head
2003 z4 2.5
Post by Gary busta Head » Wed Jul 21, 2021 10:22 pm
zriha, hi mileage is 90,000 was imported from Japan 3 years ago will try a new battery I even got the garage to remove all the carpets incase it had got wet at any point.
Gary busta Head
2003 z4 2.5
Post by Gary busta Head » Wed Jul 21, 2021 10:30 pm
enuff_zed, Mr Tidy, Hi mate I was in a Electrical specialist with all the latest gear sadly and codes were never the same twice, parts changed code cleared and then something else. I will try new battery this week . Tks
Gary busta Head
2003 z4 2.5
Post by Gary busta Head » Wed Jul 21, 2021 10:34 pm
enuff_zed, will try new battery ASAP know 1 mentioned that and I should of thought myself as the my Range Rover is run by the battery. Tks
Gary busta Head
2003 z4 2.5
Post by Gary busta Head » Wed Jul 21, 2021 10:37 pm
Ole gits rule, Thank you will get 1 this week a give it a try 😊
Gary busta Head
2003 z4 2.5
Post by Gary busta Head » Wed Jul 21, 2021 10:39 pm
1000rr, Hi and the MAF is what πŸ˜‚πŸ˜‚πŸ˜‚Tks
Ole gits rule
2003 z4 2.5
Post by Ole gits rule » Wed Jul 21, 2021 11:15 pm
Gary busta Head wrote: ↑Wed Jul 21, 2021 10:39 pm 1000rr, Hi and the MAF is what πŸ˜‚πŸ˜‚πŸ˜‚Tks
Mass air flow sensor - can cause issues with how the car runs - take a look on you tube for it :thumbsup:
zriha
2003 z4 2.5
Post by zriha » Thu Jul 22, 2021 1:25 pm
Also, if you can find in your local area a person with the same model of Z4, who is willing to give some parts for a try, like a Mass airflow sensor, or any other sensor, it is a cheap way to pinpoint the bad part.
Current fleet
