URL Problem?
kis
URL Problem?
Post by kis » Fri Mar 16, 2018 1:20 pm
For example
Kis
Which is: *url=z4-forum.com/forum/memberlist.php?mode=viewprofile&u=22673]Kis[/url*
Becomes this when you click on the link?
*z4-forum.com/forum/z4-forum.com/forum/memberlist.php?mode=viewprofile&u=22673*
Replicates Z4 forum section in bold...
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
sp3ctre
Site Admin
Site Admin
URL Problem?
Post by sp3ctre » Fri Mar 16, 2018 1:33 pm
Where did you get that link from? Looks like you are missing the https:// from the front of the url.
kis
URL Problem?
Post by kis » Fri Mar 16, 2018 1:57 pm
Kis
Which is: *url=memberlist.php?mode=viewprofile&u=22673]Kis[/url*
If I change it to the above and just start with memberlist seems to work fine? It's a link that used to work on the Carly locations thread I started a while back. Since the site update it's not happy with the links.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
sp3ctre
Site Admin
Site Admin
URL Problem?
Post by sp3ctre » Fri Mar 16, 2018 2:09 pm
Yeah, I can see that now... not sure if something changed in the behaviour in between versions. I did notice that you had www. in your links, which I have now removed from the site, but even without that it still behaves the same.
kis
URL Problem?
Post by kis » Fri Mar 16, 2018 2:16 pm
So will it stay the same? I'll just change them all to start with memberlist? Or will any future updates possibly mess that up to? Thanks :)
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
sp3ctre
Site Admin
Site Admin
URL Problem?
Post by sp3ctre » Fri Mar 16, 2018 2:18 pm
kis wrote: Fri Mar 16, 2018 2:16 pm So will it stay the same? I'll just change them all to start with memberlist? Or will any future updates possibly mess that up to? Thanks :)
I think it'll likely remain the same, unless it's a bug. If you want to make sure it doesn't break, just drop the www and put https:// in front, that way it is the correct format for a full URL
kis
URL Problem?
Post by kis » Fri Mar 16, 2018 2:19 pm
Okay cool, cheers sp3ctre!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
