Humming noise from rear of the car.
[youtube]https://youtu.be/Zq0TB4IpT5A[/youtube]
Please see the above link to the video for my issue. I've read a couple of posts on here that may resemble the same issue as mine but without any evidence attached. Has anyone had the issue and have had it resolved?
I'd love to hear from you.
I've also noticed that the noise appears more prominent next to the rear driver's side wheel. Sounds like it may be coming from behind there.
Dean
Dean
- bob20124
It sounds like the the LPFP (low pressure fuel pump).
2011 35i BMS low and high side OCC, BMW 550i Clutch, CDV delete, Custom tune by BQ Tuning, ER Charge Pipe w/Tial BOV, ER Comp. FMIC, K&N drop in, 40W LED Halo, LCI side markers, M-Factory LSD, Stubby, Windrestrictor. Dyno'd 405WHP, 458Lb/FT
- ronk
It certainly does and it's as bad as I've ever heard !
Thanks guys!
- ronk
Forgot to ask, does the noise change when the tank levels change?
- MrPT
Bees?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
It doesnt happen all the time but know that you've mentioned it it does seem worse with a full tank.
- Ewazix
Bored hoe in the trunk?
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
It could be Bee Pee in your tank
- Dr.Gonzo
Hi. Can you confirm that you hear that humming noise only when around 1/4 fuel left in your fuel tank ?
BMW Z4 35i
That's definitely the pump in the fuel tank. I had exactly the same issue on a 2010 23i. Like you describe, the noise was worse with a full tank of fuel. It's a well know problem and fortunately for me my car was under warranty. It's an expensive fix as the tank has to be removed by firstly removing the exhaust and dropping the rear suspension. The dealer had the car for a day and a half and said the cost of the repair was in excess of £1000.
Wow, thanks for this thread! I was about to post the same thing, and the description of the noise sounds exactly as you've described. For me, it's a whine, which is noticeable each time I refuel.
I first noticed it in May, after having the super from Sainsbury's for a couple of tanks, then went for Shell VPower to see if it had any difference.
The frustrating thing is the dealer can't seem to reproduce the noise!
Any suggestions from those who have had this dealt with? I'm about to book it into a different dealer to see if they can't find the problem.
2013 E89 35iS Mineral White
19" 326M | heated seats & wheel | pro nav & hifi | stubby
Gone: 2010 E89 23i Space Grey
- ronk
Mine was a 2010 3.0l
75% full tank and warmed up - very noticeable on idle - it was a warranty fix.
Thanks Ronk! It's booked in for a week Monday. Back to the same dealer that found and fixed my injectors.
