This is my boomerang indicator. It's clear, but I have applied a light smoke tint to it. They open easily; there are three clips underneath that are easily unclipped. You'll also find the amber bulb covers; I've removed mine as I didn't like the way the amber showed through the clear.
- IMG_1271.jpg (133.41 KiB) Viewed 679 times
- IMG_1275.jpg (104.57 KiB) Viewed 679 times
- IMG_1276.jpg (177 KiB) Viewed 679 times
The boomerangs screw onto the lens shrouds - if you left them out there would be a large gap at the base of the headlight:
- IMG_1277.jpg (126.91 KiB) Viewed 679 times
- IMG_1278.jpg (159.89 KiB) Viewed 679 times
A side view of the Xenon component; at the base you can see the electromagnet (the black ended circular drum with a hooked wire coming out) that, when charged, pulls the lever on the shutter; this is how the Xenon can do full & dipped beam.
- IMG_1279.jpg (137.36 KiB) Viewed 679 times
You may also notice that I had a damaged lens mount. I've repaired this with some Sugru, as it sets as a stiff rubber (no sniggering at the back) and holds the mount without cracking - I chose Sugru over some Araldite/Chemical Metal because of past experience when Araldite kept cracking under load/vibration.
And a back view, for completeness
- IMG_1280.jpg (182.21 KiB) Viewed 679 times
Let me know if you need any other pics; I'm not planning on sealing them up until this weekend at the earliest.
