What have you coded with Carly
- kis
Just double reset it when you have the next service?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
That makes perfect sense! Didn't think of that having never reset it myself.
Does Carly allow you to do that?
Black Sapphire 3.0Si Manual Coupe - Silverstone Individual Leather - Two-Tone 108s
Bilstein B12 - Michelin Pilot Sport 4 - Powerflex - MTEC Brakes
- ph001
You can do it just from the dash - no need to plug anything in the OBD
- kis
Important to do it at the service tho, otherwise you’re going to mess up the service mileage intervals.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Ah, cheers guys - I assumed you had to do it through diagnostics. Only had the car serviced last week, and it only really gets driven at weekends, so perfect timing
- MalNCH
Running the lite version from an Android with a bluetooth conection:
https://www.amazon.co.uk/gp/product/B01 ... UTF8&psc=1
It allows me to connect and run diagnostics (where you can email the results as a pdf), before I buy the full version I'm assuming that if I can do that full functionality will actually work? I keep reading you need to run android from a cable and it's an expensive mistake to make if it doesn't work.
2004 E85 3.0i, Titan Silver Metallic.
- MACK
Alternatively you could just reset it now and once again when its serviced. Its easy enough to do through the clocks.
Silver 05 3.0i SE
White E89 20i M Sport
- kis
No idea as I run iOS... I didn't want to risk it as I've heard you can run into problems with a universal adapter. So bought the adapter from Amazon? Think that's where they listed it, direct from Carly. But again different experience as I'm on iOS. Could be a completely different situation with Android…MalNCH wrote: ↑Fri Jun 29, 2018 9:39 am Running the lite version from an Android with a bluetooth conection:
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- kis
So long as it's managed properly, otherwise it could give you a false indication of your true service interval, and you might not realise till you've done (for example) 3000 miles over your service mileage.
Think it's all sorted tho as Matt_3.0Si only had it serviced a week ago, so a weeks worth of mileage is negligible
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Can you lower/raise the roof whilst moving or do still have to come to a stop first ?
On my side I've managed to remove the warning light error for parking lights deactivating the monitoring tension/voltage.
Other than that I've failed miserably to activate autmatically lock the doors when driving at 8km/h, I guess it needs to be activated alonside another setting but I am afraid to mess around with other "lock" functions. Any advice?
Other than that I plan to include the following to the list:
- Comfort open windows using remote
Windows go down on fob unlock (and hold)
- Comfort close using remote
Windows close on fob lock (and hold)
- Automatically lock vehicle
If I've unlocked the car by mistake and not opened a door the car locks itself again after about a minute
