Left fender BMW emblem replacement
I have a 2009 Z4 (E89) and the BMW decal portion of the emblem has fallen off. I bought a replacement and it is the entire emblem, with 3 prong backing. Can someone tell me how to replace the entire emblem? I've seen a few videos on trunk and hood replacements and they are different. Does the E89 version emblem have backing grommets or nuts that hold it in place or is it just snapped on? The replacement emblem prongs do not have any threads on them. Two side prongs are longer than the top, center prong.
Thanks in advance,
Tim
Thanks in advance,
Tim
- ric19
Hi, I asked this question a couple of weeks ago as mine has corroded and I have replacement waiting to go on,to the best of my knowledge the side badges just push into grommits and are held on by double sided tape, whilst the bonnet badge (which is the same badge) is held on by a couple of self tapping nuts
https://www.realoem.com/bmw/enUS/showpa ... Id=51_7504
Thanks...wasn't sure how it was fixed on. Hopefully, the old one will pry off without damaging the grommets.
Prying usually damages something, doesn't it?
Vidi, vici, veni
- ric19
Well I am planning on getting some dental floss and attemp to cut the tape and then slide an old credit card behind the badge to give me a base to try and prise against
- Nictrix
I dont suppose you could ask a friendly dealer how to remove and attach?
Realoem shows grommets for the side badges but does not say how many and nuts for the front badge.
Vidi, vici, veni
- ric19
Hi Tim done mine, I had a look in the wing with an endoscope I have and confirmed no nuts so I surrounded the badge with masking tape and stuck a credit card at the back of the badge to lever against and apart from snapping a lug off it was a piece if Cakemi24pilot wrote: ↑Thu May 11, 2017 3:56 pm I have a 2009 Z4 (E89) and the BMW decal portion of the emblem has fallen off. I bought a replacement and it is the entire emblem, with 3 prong backing. Can someone tell me how to replace the entire emblem? I've seen a few videos on trunk and hood replacements and they are different. Does the E89 version emblem have backing grommets or nuts that hold it in place or is it just snapped on? The replacement emblem prongs do not have any threads on them. Two side prongs are longer than the top, center prong.
Thanks in advance,
Tim
Rich
- 20170514_142417.jpg (98.68 KiB) Viewed 1507 times
- 20170514_142147.jpg (88.47 KiB) Viewed 1507 times
- 20170514_142138.jpg (79.15 KiB) Viewed 1507 times
- Zed Five
How much were the replacement badges? From bmw? I need to get around to doing mine.
Why is it that people who can't take advice always insist on giving it?
E89 35is | BMW S1000rr Motorsport Ed.
- Nictrix
When you see the amount of dirt that gets caught behind these there should be a better way of attaching them.
- ric19
I got mine off Ebay from a BMW garage in Hull for £31 Inc delivery..dear for what it is considering I got 4 wheel badges that look OEM off Amazon fir £12.99..it was £36 from the local BMW garage for the side badge
The I/C you need is
51147044207
- ric19
Only one I can find on Ebay
http://m.ebay.co.uk/itm/BMW-Genuine-Fro ... 0946799495
- jimbo1958
Good work Rich.ric19 wrote: ↑Sun May 14, 2017 2:29 pmHi Tim done mine, I had a look in the wing with an endoscope I have and confirmed no nuts so I surrounded the badge with masking tape and stuck a credit card at the back of the badge to lever against and apart from snapping a lug off it was a piece if Cakemi24pilot wrote: ↑Thu May 11, 2017 3:56 pm I have a 2009 Z4 (E89) and the BMW decal portion of the emblem has fallen off. I bought a replacement and it is the entire emblem, with 3 prong backing. Can someone tell me how to replace the entire emblem? I've seen a few videos on trunk and hood replacements and they are different. Does the E89 version emblem have backing grommets or nuts that hold it in place or is it just snapped on? The replacement emblem prongs do not have any threads on them. Two side prongs are longer than the top, center prong.
Thanks in advance,
Tim
Rich
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Jaguar F Type V6s Roadster
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
