35is Running temperatures
- RayM
Hi guys
Just wanted to ask where your temperature gauge sits on your 35is models?
Mine seems to take ages to warm up, at least by what the gauge is saying. It never gets to the 120c middle of the gauge but sits around 90-100.
What do you guys see?
Porsche 997 Gen 2 Cab - awesome
Melbourne Red 35iS (Gone to a new Home)
3.0 SE E85 Maldives blue (Now gone but not forgotten)
Previous toys:- 2.0 Litre Westy, 993 C4
- jleckenby
Sounds about the same as where mine sits
Z4 35is, 438bhp
Cobb Stage 2 (Aggressive), VRSF Catless Downpipes, BMS DCI, NGK Iridium Spark Plugs, Eibach Springs
- Wrs
Yup it will take quite a while to warm up.. at least 5+ miles. I find normal running temp is 90c.
Gone - Black Sapphire Z4 E89 35is
Gone - Midnight Blue Z4 E85 3.0si
- Chris_D
If you're really curious to know the 'real' operating temperatures of various engine components, investing in Carly Pro and using the 'live parameters' feature is very useful. Helped me diagnose a cooling issue when I first bought my E85.
It logs everything too for post-drive analysis.
It should sit at 90 degrees....
120 is wayyyy to hot.....
- s.m.456
It's the same with the 135i, same engine. It's nice to have a visible oil temperature gauge opposed to just the general water temperature found in most cars. It's a nice visual reminder to promote restraint before everything is nicely warmed up.
The temp can rise to 110 when really pushing on, but will quickly drop back to 90 when on a cool down run.
Current: Z4 3.0Si Roadster viewtopic.php?f=6&t=98835
Past: Toyota Corolla T-Sport, BMW 08' 135i with all factory toys: http://www.babybmw.net/forum/viewtopic.php?f=11&t=84085
Mine takes around 10 minutes until it's off the 70C mark but then quickly moves up and sits around 110C if I'm in heavy traffic or pushing on maybe closer to 120C. Apparently that's normal for the N54T.
2013 E89 SDrive35is - Melbourne Red
2005 E85 Alpina Roadster S Lux - Japan Red - SOLD
- RayM
Thanks guys that's all good then. I was a little concerned as almost every other car I've had over the last 20 years normally sit with the needle in the middle of the gauge, so all your comments put my mind at rest
- Smartbear
Yep, the oil takes a lot longer to warm up than the coolant-my n20 engine is the sameRayM wrote:Thanks guys that's all good then. I was a little concerned as almost every other car I've had over the last 20 years normally sit with the needle in the middle of the gauge, so all your comments put my mind at rest
e85 3.0si sold
Onlineronk
Is there an oil cooler on the 35is and if so, is it just open circuit or does it have a thermostat ?
just curious !
just curious !
- Nanu
Mine likewiseGlyn wrote:Mine takes around 10 minutes until it's off the 70C mark but then quickly moves up and sits around 110C if I'm in heavy traffic or pushing on maybe closer to 120C. Apparently that's normal for the N54T.
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
Onlineronk
I haven't had a chance to try my 35is yet but my previous 3.0l oil temp used to be very stable even in hot weather but would climb very quickly when put under any stress i.e. Mountain pass in summer (Splügen) it would drop equally as quickly when the throttle was relaxed.
I'm still unsure if the oil is cooled and if it is cooled, is it thermostat controlled?
Oil temp is directly related to block temp which is thermostatically controlled with coolant. In the 35i/iS there is an additional oil cooler in the front side bumper intake.
Onlineronk
Maniac wrote:Oil temp is directly related to block temp which is thermostatically controlled with coolant. In the 35i/iS there is an additional oil cooler in the front side bumper intake.
I thought there was but is that thermostatically controlled?
- R.E92
If you think the engine oil takes a while to warmup then take a look at the DCT transmission fluid temp. Takes a good 40min to warmup for me!
