Help me decide - Job done . . .
- paddy wright
Help me decide . . .
Thought I'd havre the black- until I saw the photos. It really adds to the look you are going for!
- Stuartt
Like the black on red as I have always said Colin, and like others have said I think you should also do the mirrors
Stuart
Stuart
2004 3.0i SE Roadster , GONE to a good home
2010 e89 35i Sdrive M sport. GONE for salvage but has been reborn
2014 e89 35is M-Sport Design Pure Traction
- Marlon
Hadn't considered plasti-dip, would I spray it straight on to the pillar? Does it peel off to revert back?markeg wrote:A while back I pasti-dipped the wing mirrors black (easier than wrapping) - may be a easier option for the door pillars as well, and simple to remove if you change your mind, Marlon?
Gone: 3.0si 2008 E85
911 997 Carrera S
Plenty of Youtube videos showing how Marlon - looks the easiest way to try black. . .
- markeg
Yep, dead easy. Make sure your pillars are clean (I also waxed the wing mirrors for easier peeling afterwards), mask up and then just spray on. Lots of thin coats is bestMarlon wrote:Hadn't considered plasti-dip, would I spray it straight on to the pillar? Does it peel off to revert back?markeg wrote:A while back I pasti-dipped the wing mirrors black (easier than wrapping) - may be a easier option for the door pillars as well, and simple to remove if you change your mind, Marlon?
Can withstand hose and gentle washing, but a pressure washer will lift the pasti-dip.
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- Chris_D
Seriously, colin, option for whole car wrap in black is missing. Dafeq is that about???
- Marlon
Thanks mate - sounds like the way to go Is plasti-dip the same as Plastikote?markeg wrote:Yep, dead easy. Make sure your pillars are clean (I also waxed the wing mirrors for easier peeling afterwards), mask up and then just spray on. Lots of thin coats is bestMarlon wrote:Hadn't considered plasti-dip, would I spray it straight on to the pillar? Does it peel off to revert back?markeg wrote:A while back I pasti-dipped the wing mirrors black (easier than wrapping) - may be a easier option for the door pillars as well, and simple to remove if you change your mind, Marlon?
911 997 Carrera S
- markeg
Nope, different stuff than plastikote. I use a version of pastidip from Frost (link) - same stuff but a lot cheaper. Link is for one aerosol...
current: MB C-class
current: MB C-class
Love the black, especially with the hard top - makes it look like a coupe.
Also... not sure if you've noticed, but even though it's an E89 the graphic for the forum is red with black pillars.
Black all day long. Defo worth trying Plastidip along with some of their glossifier if you want it to better match your roof.
- Silverzedtom
Another for black here. Looks great with the lid on and with it off too. if you go down the wrap route then it's a little bit of stone protection too , I had a vile stone chip on my old cars pillar and it never looked right even after a touch up. I have to admit I'd probably try plastidip as it sounds so easy to apply and revert back to oem.
E85 2.5si
F55 Cooper S
F55 Cooper S
I'm voting black A pillars,door mirrors and roll hoop covers.
On my E89 the pillars were already gloss black so I opted for matching roof sections and door mirrors as the pillars stood out (glaringly IMO)........roll hoop covers were the only "silver" bits visible in the cabin and also stood out a bit....and not in a good way(looked like the cheap plastic that they are)
The only guy I got a quote from for wrapping the roof said there would probably be some white paint showing around rear window recess so I opted for paint and rear window out for this.Think I'd give it a go yourself to be happy with the end result rather than pay to have it wrapped and still have red showing by the windscreen/door.
- Marlon
Thanks everyone
At time of posting its a landslide 78% for black so I'm going for it.
Going to use Plasti Dip (possibly with a final coat of 'glossifier')
Just need to order the paint and wait for a dry still day.
I'll post back when its done,
Cheers,
Marlon
Cheers,
Marlon
911 997 Carrera S
- patriot66
Hi Colin. Don't bother with the Glossifier. I have tried it on my grilles over black Plastidip and it marks/scratches up far too easily as it is very soft.Marlon wrote:Thanks everyone
At time of posting its a landslide 74% for black so I'm going for it.
Cheers,
Marlon
- RickRob
Go black. I too would like see the mirrors in black as well. Then keep going until it's all black!
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
