enuff_zed
Post by enuff_zed » Sat Apr 27, 2024 8:56 am
steve69 wrote: Sat Apr 27, 2024 8:50 am Soft top clean and re protect yesterday
Also installed the led numberplate lamps. Now 100% led
How did the roof come up?
I gave it four deep cleans just to get the slime out of it!
HQ of 'Norfolk Zed Rescue'.
steve69
Post by steve69 » Sat Apr 27, 2024 9:05 am
Can't tell right now it's hammering it down! I left the soap on overnight so will apply the protection when the rain stops, I did think it'd been done it was looking pretty good, might be in need of a re dye!
The old halogen licence plate lamps will be listed for sale, they could do with a clean but they're all working and I didnt break the clips removing them :thumbsup:
toledo
Post by toledo » Sat Apr 27, 2024 10:35 am
True-Blue wrote: Sat Apr 27, 2024 8:24 am
toledo wrote: Fri Apr 26, 2024 10:07 pm Fitted a GruppeM intake to my Alpina. All I can say is holy cr*p this thing sounds good! Can't wait to take the car out of the city and absolutely nail the throttle.
Is there a specific version for the Alpina? Or does the 3.0i M54 version fit?
There is no specific Alpina version. The one listed on the GruppeM website for the Alpina is exactly the same one listed for the 3.0l and shares the same part number. I was a bit worried when I saw this on the outside of the box when it arrived but then having checked, they are in fact exactly the same for both variants.
Just noticed that there is in fact a pre-facelift and facelift version though so just be aware of that. The one that fits the Alpina is the pre-facelift version. The facelift version - https://jp.gruppemdirect.com/en-eu/prod ... 4b7e&_ss=r is slightly different. On pre-facelift cars the MAF housing is able to be unclipped from the airbox whereas on facelift cars it isn't so GruppeM provide an early or late version accordingly. On the facelift version you would remove your MAF from the old airbox and install it into the custom housing that they provide in the kit.
Big Andra
Post by Big Andra » Sat Apr 27, 2024 2:17 pm
Fitted a new headlight level sensor arm.
2009 E89 2.5 Alpine white.
Fred Smith
Post by Fred Smith » Sat Apr 27, 2024 2:59 pm
j3nks79 wrote: Mon Apr 22, 2024 1:42 pm I put mine in the dishwasher after I split them.
Rubbed them down and sprayed with chrome enamel paint from Halfords. A good 3 coats and they turned out great.
Then I spray tinted the lenses with a dark smoke.
Got some tiger seal and sealed them back together. No water or moisture is getting through that stuff.
I'm hoping to seal mine later.. how mcuh tiger seal did you use and do you have any tips? Presumably neatness is a low priority? What sort of diameter sealant would you use? Thin toothpaste? Is it easier to use too much or too little?
9designs
Post by 9designs » Sun Apr 28, 2024 3:07 pm
Picture says it all..........
Oil Seals.jpg (17.48 KiB) Viewed 412 times
57 Plate 3.0 Si Auto SilverGrey - Red Leather
E89 35iS Space Grey - Red Leather. SOLD
56 Plate 3.0 SI Manual - Black with Red Leather- Scorpion exhaust, BC coil overs SOLD
54 Plate 3.0 SE Auto - Silver with Red Leather. SOLD
j3nks79
Post by j3nks79 » Sun Apr 28, 2024 3:58 pm
Fred Smith wrote: Sat Apr 27, 2024 2:59 pm
Just a bead in the channels. Half of what you would get out of the toothpaste
2009 09 Carbon Black Cinnamon E86
Fred Smith
Post by Fred Smith » Sun Apr 28, 2024 5:32 pm
j3nks79 wrote: Sun Apr 28, 2024 3:58 pm Just a bead in the channels. Half of what you would get out of the toothpaste
Thanks. Will take your advice!
My "bumper off to sort the headlight washer leak and sort condensation in NS headlight" is now about a week into what I think will be two weeks off the road. Washer leak sorted, headlight de-condensationed, two foglights refurbed (but lenses still to go back on).
Today I have removed and sanded the strut behind the grill and the bonnet retainer bracket, ready for painting. Also sanded some rust spots on the chassis beneath where the top of the bonnet is bolted ready for rust treatment and repainting. I have what seems to be a common crack on the bonnet between the two kidney grills and I bought a plastic welding kit - still considering the best way of strengthening the area to the rear of the bonnet where it's racked before rectifying the visual fault to the front. Still waiting for a new headlight washer cap (for visual effect only, I am not going to buy one or two new headlight washers the car needs because I don't see they add anything at all to the car). And that'll need painting before going on. I want to do it before the bumper goes on because I want to fix it from behind and opposed to gluing it - I want it to be as easy as possible if myself or a future owner decides they want the washers working.
MikeyH
Post by MikeyH » Mon Apr 29, 2024 1:30 pm
Past its MOT today, advisory re oil on outside of gearbox? couldn't give me a clear answer as to what it might be except it would need wiping off and then waiting. They managed to break my drivers seat belt guide again, been putting off buying one as it has been okay since glueing it together last year. Now is the time to get one I think :thumbsup:
chanlon1
Post by chanlon1 » Mon Apr 29, 2024 2:37 pm
New ground cable put in today (courtesy of the AA, not me :D )
Couldn't get the starter motor to start even though it was brand new.
Transpires it was a corroded cable.
E86 Z4 Coupe 2006 Silver
Online
1536Z4
Post by 1536Z4 » Mon Apr 29, 2024 7:07 pm
chanlon1 wrote: Mon Apr 29, 2024 2:37 pm Transpires it was a corroded cable.
Looks like your avatar has been nibbling on it :)
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
chanlon1
Post by chanlon1 » Mon Apr 29, 2024 7:23 pm
1536Z4 wrote: Mon Apr 29, 2024 7:07 pm
Fed after midnight
Rsipad
Post by Rsipad » Tue Apr 30, 2024 3:24 am
Got an alignment done after fitting new suspension. It's pretty aggressive for dual duty driving but I think it will be fine:
Front Camber: 3.0 degrees
Front Toe: 0.08 degrees total
Rear Camber: 2.0 degrees
Rear Toe: 0.12 degrees total
Now time to get out there and test it :driving:
2006 Z4 3.0i (Montego Blue)
Online
1536Z4
Post by 1536Z4 » Tue Apr 30, 2024 12:13 pm
Rsipad wrote: Tue Apr 30, 2024 3:24 am Front Camber: 3.0 degrees
Please report back on how you get on :thumbsup:
steve69
Post by steve69 » Tue Apr 30, 2024 12:28 pm
Tagged
WhatsApp Image 2024-04-30 at 12.25.59_313a78ef.jpg (79.4 KiB) Viewed 173 times
