you have to work on them whilst they are hot and the sealant is softFred Smith wrote: ↑Mon Apr 22, 2024 6:53 pmI am far from convinced that the hot water did much good... but it still soaking (cold now).... in the meantime, with a pen-knife, small screwdriver and gentle use of a car interior removal tool thing I got the second one apart dry in about an hour or an hour 15.
- Reamesy
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
I put them in boiling water and checked a few times and there seemed to be little to no softening. I shall try again and attack them with a knife soft this time.
Edit - didn't bother re-heating in the end, but the softened and soaked light took less than half the time of the dry one.
OnlineSimonAW
Fitted some new non M steering wheel trims bought from the forum, pleased with how it has turned out...
- IMG_2150.jpeg (204.95 KiB) Viewed 373 times
OnlineUsel
OnlineSimonAW
Lol, yeah..
Just need to pull off the cowling and see if the car is pre-wired, it's 56 plate 07, so unsure if it will be. Fingers crossed, but no biggie if not.
- Rsipad
Fitted BC Racing BR coilovers on my Z4 last week. Am planning on lowing the car a little more today but that almost didn't happen; someone ran a red light and almost t-boned me at ~55mph
2006 Z4 3.0i (Montego Blue)
Online
Unlikely, only pre Sep 04 cars came with the full loom.
2003 Maldives Blue 3.0i auto
OnlineSimonAW
Just checked and mine is wired, so that’s a bonus.
- IMG_2154.jpeg (98.49 KiB) Viewed 300 times
OnlineUsel
Online
MFSW wiring should be in all Cars manufactured from October 2003
Previous to this to get MFSW to function you need a 2 wire modification from the Squib green plug to the LCM
Online
Good to know. Everyday is a school day.
- steve69
Gents! Ripped out the absorbant foam, thanks for the tips by the way, live and learn!
Rust treated & protected the inside of both doors (even though there was no signs of any rust at all) Replaced with butyl foil panels and a layer of closed cell foam. Installed oem speakers from umfaan and connected to the tweeter line, easy as and it all works a treat. Huge difference! Car doors feel and sound heavier and the audio quality in the cabin has improved 10 fold.
While I was working a bloke rode up the street with a split in his tyre, I offered some tyre weld but said it probably wouldn't work (it didnt), he then begged for money and food, I made him a sandwhich and some water, refused him dosh and he drive off with a flat tyre having 5 fingered my jack, and leccy tape. No reward for kindness these days, geezers probably used it to nick one of my neighbours wheels I bet...
So I need to buy a new jack, as my radiator replacement has just arrived, current ones cracked and not leaking slow.. then will refill the coolant and bleed the system
- 20240423_155729.jpg (106.69 KiB) Viewed 221 times
- 20240423_201328.jpg (119.85 KiB) Viewed 221 times
- Barty
Got it aligned in prep for the trip
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
- Ed Doe
Just remembered, my mate who had this exact exhaust set up (same OE cats, X-pipe & Cans) that Donny evening session we met at last April was out on track with no issues, so unless they've changed their criteria since I should be ok!
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, Supersprint, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- 1536Z4
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
