Ed Doe
Post by Ed Doe » Sun Apr 21, 2024 7:42 pm
BMWZ4MC wrote: Sun Apr 21, 2024 1:44 pm Looks great Ed, and pretty clean despite you suggesting otherwise :thumbsup:
Thanks dude, just reread the top of the page and saw your update too - I had a similar situation about 2 years ago, replaced with bosch coils too, the car definitely felt a chunk livlier as well!
Yours looks very good too - when's the next trackday?! I've got an evening slot at donny booked for next Monday, and then a ring trip in may with mates. Can't wait 8)
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, Supersprint, RTD, 4.1FD :evil:
Silver Grey '06 3.0si Coupe - SOLD :(
1536Z4
Post by 1536Z4 » Sun Apr 21, 2024 8:09 pm
BMWZ4MC wrote: Sun Apr 21, 2024 6:02 am They're Bosch coil packs that match the OEM specifications
:thumbsup:
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
1536Z4
Post by 1536Z4 » Sun Apr 21, 2024 8:12 pm
Ed Doe wrote: Sun Apr 21, 2024 1:05 pm Fitted supersprint x-pipe and rear cans,
Are you happy with them ? .Looking good to me :thumbsup:
True-Blue
Post by True-Blue » Sun Apr 21, 2024 9:30 pm
Rear shocks on the Mrs E89, actually prefer doing these to the E85 now I’ve worked out how to access the top mounts without removing nearly all the boot trim.
For anyone who doesn’t read the E89 section, this is why you should budget for suspension refresh when buying an E85/86/89 if it hasn’t been done already…
Totally shot after 62k despite looking decent enough and not leaking, no damping at all…pushed the pistons in with almost zero effort and they’ve still not moved hours later.. car feels transformed even with just the rears done. Fronts when I have a bit more time :thumbsup:
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
Big Andra
Post by Big Andra » Sun Apr 21, 2024 9:41 pm
Got a bit carried away with the cleaning today and decided to remove the wheels too.
Before
After
2009 E89 2.5 Alpine white.
jenniferlouise
Post by jenniferlouise » Sun Apr 21, 2024 10:18 pm
True-Blue wrote: Sun Apr 21, 2024 9:30 pm Rear shocks on the Mrs E89, actually prefer doing these to the E85 now I’ve worked out how to access the top mounts without removing nearly all the boot trim.
What did you replace them with? OE or something else? I’ve done rear springs on our E89 but not dampers…
True-Blue
Post by True-Blue » Sun Apr 21, 2024 10:23 pm
jenniferlouise wrote: Sun Apr 21, 2024 10:18 pm
Bilstein B4 (O.E. Equivalent), Sachs weren’t available at the time I was ordering from autodoc but are back in stock now
Online
steve69
Post by steve69 » Sun Apr 21, 2024 11:26 pm
Soundproofed the driver side door and installed a oem midrange speaker.
Greased the steering column gear rod with the teeth at the bottom today (the one with the rubber sleeve) did driver and farside. Managed to reuse those clips but in future I'll buy a crimping tool for them I think. Had steering with a lot of resistance and a bit of a squeak and a creak so I've been trying to sort that out. Silicon sprayed the UJ's also, squeak has gone but I still have the 'creak'
Switched out the halogens for LED's, now just need to code out the dash error.
Any suggestions on the steering, it's like a rubber creaking as if rubber was rubbing tightly on metal kind of noise?
Also ID'd a coolant leak, coming from the rad, Martin's kindly reimbursed me the price of the radiator and labour! What a gent, well worth buying from him definately.
Freya's a fighter, she's giving me a bit of trouble but with some love she'll turn out alright :wink:
BMWZ4MC
Post by BMWZ4MC » Mon Apr 22, 2024 12:16 am
Ed Doe wrote: Sun Apr 21, 2024 7:42 pm
Both will be great fun. I’ve still not made it to the ring, but I’d love to drive it one day.
No track days for me for the foreseeable future - work is busy and two kids of one and three and a half years keep me busy at home too.
Hopefully, towards the end of the year I’ll have more time. For now, I’m taking the scenic route home as often as possible :driving:
S2000 GT - gone
x-driver
Post by x-driver » Mon Apr 22, 2024 12:28 am
steve69 wrote: Sun Apr 21, 2024 11:26 pm
Google search for "sticky steering ring fix". There is some adjustment ring on the servo motor just under the steering wheel in the dashboard. Moving it for 5-10mm is said to fix the sticky steering problem, might fix the creak as well.
Reamesy
Post by Reamesy » Mon Apr 22, 2024 7:39 am
steve69 wrote: Sun Apr 21, 2024 11:26 pm Soundproofed the driver side door and installed an oem midrange speaker.
That foam backed sound insulation will hold water and rot your door. The door has drain holes as water will get in the top. The plastic membrane you removed is normally a common failure allowing water to get into the cabin area.
A foil backed deadening would achieve the result your are after and make sure you fully seal the membrane when you reinstall it.
As for your creak. Check the wishbone rear and front mounts. Get someone to turn the steering wheel as you put your hand on them. Usually feel them creek. You will need the weight of the car on the ground so it will be tight unless you have a lift. 👍
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Ed Doe
Post by Ed Doe » Mon Apr 22, 2024 8:08 am
1536Z4 wrote: Sun Apr 21, 2024 8:12 pm Are you happy with them ? .Looking good to me :thumbsup:
I've honestly not driven the car besides nosing it about on the drive - I didn't have time considering I wanted to try and polish it afterwards. Ran out of time for that too but heyho, always next weekend!
BMWZ4MC wrote: Mon Apr 22, 2024 12:16 am Both will be great fun. I’ve still not made it to the ring, but I’d love to drive it one day.
If you do get a 'ring date in the diary let me know - if I can manage to get out there too I certainly will :)
Yeah my son is 3 1/2 too now, and we've got a second child on the way (not sure if boy or girl yet - due October), so I'm getting the trackdays in this year, as I'm pretty sure I'll be limited to taking the scenic route home too next year! :lol:
Online
steve69
Post by steve69 » Mon Apr 22, 2024 8:50 am
Reamesy wrote: Mon Apr 22, 2024 7:39 am
Hadn't thought about water in the doorframe.
Behind the layer of eggshell foam is rubber and closed cell foam (won't absorb moisture) I've replaced the butyl and plastic/foamlike membrane, but that's not going to stop the eggshell sucking up water that runs through the window seal like a sponge
Foil, closed cell foam and rubber are great at impact sound and vibration-noise deadening but they don't dissipate airborne sound waves as well, was just being super precise, the eggshell foam was to help with reverb and improve the sound quality both inside the cabin and from the midrange speaker.. Can't believe I didn't think moisture absorption didn't dross my mind :headbang:
Still one good thing is I'll rust protect the inside of the door when I rip it out, and will do the same when I soundproof the passenger side
Thanks for the tip on the wishbones, I have a ramp that'll hopefully help me get some lift, don't fancy the squeeze, I'm not even sure my arms are long enough!
Online
Fred Smith
Post by Fred Smith » Mon Apr 22, 2024 9:12 am
Well, my first job of the day was check N/S headlight for newly formed condensation and to try to work out why it stopped working yesterday after I dried it out.
No condensation, but given the time of year and weather I'm not taking much comfort yet. The headlight and side light weren't working when I re-installed yesterday, this morning the headlight was back working for some reason, and a bit of tightening of the side light bulb and I seem to have it all back to 100%. Fingers crossed.
Online
Fred Smith
Post by Fred Smith » Mon Apr 22, 2024 1:07 pm
Second job of the day I used heavy machinery (marginal exaggeration) to get the fog light bulbs removed from the front fog lights. With the help of a toothbrush I've removed a pile of reflective metal flakes and corroded metal about the size of a tennis ball from inside the two fog lights. Debating whether to keep poking and prodding to get as much out as possible or whether just blast the inside with a jetwash and then dry it out. I want to do a proper job but slightly concerned about not being able to dry them properly (not that they are completely dry right now.)
