Disa valve advice please
Hey,
Bizarrely the disa on my 99k 04 3.0se is fine, pin tight, flap connected, nice and clean all round, however there is approx 5mm loose play in the flap. I don't know if that's acceptable or if the flap should be fully tight with zero play, for the job it does I'm thinking it should be fully tight and it might be on its way out with a replacement a good idea. Anyone any idea and if I ought to buy a new valve does anyone have a preferred outlet? Plenty on the bay but there's a consensus that I should buy from X then I'll do that. Any thoughts? The pics below show the amount of free movement in the flap.
Thanks very much as always.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Valve play
- IMG_0498.JPG (97.53 KiB) Viewed 1848 times
- IMG_0497.JPG (105.65 KiB) Viewed 1848 times
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- markplant
http://www.i6automotive.co.uk/disa-valve-kits/
based in sheffield
have also seen another that looks more substantial but cant find the link
based in sheffield
- markplant
- Chris_D
Good to check the DISA every couple of months John so props to you as you may have caught it while on its' way out.
A simple further check is to rotate the flap back until you can place your finger over the small air inlet hole - if the flap holds its' position with your finger over the hole then at least the diaphragm is ok. play in the flap will be indicative of the internal spring/bearing mech beginning to fail.
There are repair kits all over the internet including an aluminium flap version. Ovekill imo but at least its their as an option.
I'd be tempted not to drive it until replaced/repaired as the flap pin can also work its way loose and into the engine - that will be catastrophic if ingested.
Also a good idea to give it a cleanup with an old toothbrush and some silicone spray (plastics) or similar
Further info here:
https://www.germanautosolutions.com/diy ... it_diy.php
good luck!
Further info here:
good luck!
- Chris_D
Also, be careful not to overtighten the torx bolts on replacement, as I did. you'll remember my 'Betty's first tantrum' thread or the separate thread I made re the bolts but OMG what a PITA that was!
viewtopic.php?f=3&t=90630&hilit=torx
Suggest a mere soupson of copper grease / antiseize on the threads for future inspections....
you know i must of had 12 bmw's now and never changed a single disa valve.
- Chris_D
goldbcfc wrote:you know i must of had 12 bmw's now and never changed a single disa valve.
they were all probably broken/loose if id checked though its a weak point on most with disa valve....
Ordered a 3lt more detailed kit from these guys Mark, good to shop locally, cheers for the link mate.markplant wrote:http://www.i6automotive.co.uk/disa-valve-kits/
based in sheffield
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Yeah I always refit everything with a dab of copper slip Chris. Thanks for the post mate.Chris_D wrote:Good to check the DISA every couple of months John so props to you as you may have caught it while on its' way out.
Further info here:
good luck!
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- markplant
Are you fitting yours, as I bottled it an gave kit to mm for his,john-e89 wrote:Ordered a 3lt more detailed kit from these guys Mark, good to shop locally, cheers for the link mate.markplant wrote:http://www.i6automotive.co.uk/disa-valve-kits/
based in sheffield
- Smartbear
I think the n52 engines have a different disa that doesn't cause the same issues.goldbcfc wrote:they were all probably broken/loose if id checked though its a weak point on most with disa valve....
e85 3.0si sold
Yes I do all my own spannering Mark, always have done, I'm too tight to pay someone else...markplant wrote:Are you fitting yours, as I bottled it an gave kit to mm for his,john-e89 wrote:Ordered a 3lt more detailed kit from these guys Mark, good to shop locally, cheers for the link mate.markplant wrote:http://www.i6automotive.co.uk/disa-valve-kits/
based in sheffield
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- markplant
If you find it a relative straight forward job with the kit you ordered, would you do another for some monies
