Broken Springs - List (add yourself if you've been affected)
- PAC_Z4_F31_110Puma
Yet another case... OSR, B8's and eibach's arriving today (might regret but will see.. non-runflat's fitted so hopefully an offset to being harsh) plus a good excuse to refresh breaks at the same time, but this is opening up pandora's box and brake pipes are starting to corrode..
2006 E85 3.0Si - Restoring a previously unloved gem. Addressing all common faults one at a time..
F31 - rapidly approaching 200k miles & Defender 110. Glutton for mechanical punishment.
Regret the username... Peter
- tomscott
Interesting one... mine was in for a new rubber and while the wheels were off I checked for broken springs and this was what I observed....
What do you think has the passenger side been put on upside down or the wrong spring... its in today for an inspection II so going to have it checked and sorted but anyone any ideas? 06 Z4MR
Passenger isnt broken just a shadow.
This is the unbroken one from the pair I just replaced. Cold be the photo angles but neither of yours seem to have tails at each end. Mine is a genuine spring. Hope it's some help.
- IMG_20210831_164015.jpg (134.9 KiB) Viewed 12088 times
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
- tomscott
They are OEM springs, the driver side is correct as far as im aware as I replaced it myself and made sure but the passenger was done before I bought the car and then the driver broke not long after and I swapped. Just wondering if the passenger has been replaced with a front not a rear.
Just a thought Tom, but have you contemplated both sides being broken, losing the bottom tail from the drivers side since you replaced - do you have a picture from when you first installed it? And top and bottom from the passenger side, could potentially correlate with the number of coils and the OEM in Nicks, although you'd certainly have reduced the ride height if that were the case.
You mean I don't have the auto-lowering option ? Yes add me to the list, 2003 e85 both rear springs at less than 80k miles
- Zed Baron
Just replaced my second rear spring on my E89 at 34k (first maybe at around 28k), they both broke at the same place the pigtail at the bottom
Had both rear spring replaced some time ago about 74k. Too many speed bumps etc near where I live so expected it. Apart from battery, bulbs tyres and leaky auto box gasket, not bad for nearly 10 years ownership I guess,
Add me to the list, passenger side has gone along with the handbrake on the same wheel.
2005 E85 with 85,000 on the clock.
2006 Z4 3.0i manual gearbox
Rear passenger side went last week at 161,000 kms. Will be replacing both sides.
- sw4nny
Slightly of topic but my wife has a seat ibiza with 30k miles on 65 plate so far 3 broken springs and 2 wheel bearings.
So it aint just our zeds,
Wonder if the seat forum has a topic titled the same
- tiglon
I had a Citroen with a broken spring at 35k. Surely it's more a problem with British roads than the BMW build/spring quality?
My E85 had a couple of broken springs at 70k, but it was a 14 year old car so probably a bit late to complain to BMW and I was more bothered by the serious engine problems.
2014 E89 35is Valencia Orange 788M wheels (M2 Competition), E90 M3 control arms, Eibach Pro Kit Springs, MHD Stage 1
Mine were replaced by the previous owner, I always try to avoid speed bumps
2008 BMW e86 Z4 Coupe Si Sport, Titanium Silver, Auto - loving it!
2005 Mini R50 Park Lane JCW Royal Grey
2011 Mercedes W204 C250 Iridium Silver Auto - Gone
2010 BMW e90 325d M Sport Space Grey Auto - Gone
Lol i just discovered this post. Is it too late to add mine? lol. I noticed at 85k miles my stock normal suspension rear springs were cracked near the taper. I replaced them with the Lesjofors non tapered M sport springs. Im not sure how long they were cracked lol. Im sure its been like that for a while now but i didnt really notice. Just wasnt enjoying going over the bumps so i refreshed the entire suspension itself.
- Jembo
Linking my post about how just to buy rears.
One of my Eibachs went just after 7k… the OEM’s lasted 60k… go figure
viewtopic.php?p=1966487#p1966487
- E61A0D3B-C3E0-4EB0-BD5F-7456277E43EB.jpeg (127.36 KiB) Viewed 5585 times
Lifer 54
Lifer 54
