What Am I Doing Wrong? ( Center Vents )
goon
Re: What Am I Doing Wrong? ( Center Vents )
Post by goon » Tue Nov 15, 2011 9:24 pm
once the vent is out how does the radio remove?
Taz
Post by Taz » Tue Nov 15, 2011 9:26 pm
the radio is fastened with 4 screws
srhutch
Moderator
Moderator
Post by srhutch » Tue Nov 15, 2011 11:50 pm
Taz x wrote:the radio is fastened with 4 screws
Two more than everybody else then :poke:
nfarmer
Post by nfarmer » Tue Dec 13, 2011 12:03 pm
Great thread many thanks if it haddent been for this thread would not have been able to install a Brodit phone mount
Cov_Lee
Post by Cov_Lee » Thu Jan 26, 2012 5:13 pm
Just managed to get mine off in 15 mins which I was pretty pleased with for first attempt!
Putting it all back together though - can someone advise if the bottom of the radio should be flush with the dash or if it sticks out by a few mm?
I can't get the radio to slide back any further and the sides where the screws hold it in bring it flush to the dash, but it overhangs slightly at the bottom - can't remember if it did this before I took it apart or not!!
There seems to be a notch at the bottom so not sure if I'm not lining this up correctly or if it's as far back as it will go!
:headbang:
navid.v
Post by navid.v » Thu Jan 26, 2012 7:13 pm
Cov_Lee wrote:Just managed to get mine off in 15 mins which I was pretty pleased with for first attempt!
:headbang:
have a look here but I think it is flush with the dash
http://www.z4-forum.com/forum/viewtopic ... 60#p440160
Faheemo
Post by Faheemo » Sun Sep 09, 2012 8:14 pm
This link shows the clips and how they work.
http://www.bimmerfest.com/forums/showpo ... stcount=16
sb78
Post by sb78 » Sun Sep 30, 2012 11:36 pm
Glad I discovered this forum & this thread!
Installed my Dension Gateway BT Lite this weekend. Taking the glove box out made routing the cables much easier.
I ended up getting the trim removal tools from the dealer as it felt like I was going to break the vents using screwdrivers & knives.
Even with the tools, it still needed a lot of force to pop the vents out.
Thanks, Scott.
vanilla
Post by vanilla » Sat May 04, 2013 12:17 pm
I'm trying to take out the vents and have managed to get the clip on the left hand side and surely enough that side the vents are giving way but the right hand side i'm having trouble. I cannot see a clip on the right hand side and cannot find it with the screw driver either. It seems to be broken or missing and the vents are not giving way on the right... :headbang:
2.0 SE Z4 Roadster Sapphire Black, Red Leather.
MM gear knob.
R. I. P :(
vanilla
Post by vanilla » Sat May 04, 2013 12:19 pm
haha just got it now, by sitting on top of the handbrake, gives me a nice central view of the vents. :thumbsup:
MM gear knob.
R. I. P :(
Stuart Truman
Post by Stuart Truman » Sat May 04, 2013 12:31 pm
vanilla, Fitting a stereo?
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
vanilla
Post by vanilla » Sat May 04, 2013 12:36 pm
yep - in the process. :) wish me luck! Just about got the bmw radio out. One of the connection on top of the left vent clip has worn away that's why that side clip was much easier to mainpulate.
MM gear knob.
R. I. P :(
Toucan
Post by Toucan » Mon Jul 29, 2013 12:36 am
The one true tool!
I've been struggling with finding a way to reliably unclip the vents. If I put a screwdriver/knife up in there I can feel the vent but I can't get the knife above it to pull down.
I did have success with an unbent paperclip but it still took 5-10 minutes.
Finally, I have cracked it with a hair grip (not mine, stolen from a lady walking past me in the street.) It's long enough, thin enough and firm enough when unbent. Just put a 5mm hook in the end with a pair of pliers and 60% of the time it works every time.
csquire4
Post by csquire4 » Sat Nov 19, 2016 8:39 pm
I followed various guides and had proper removal tools but could not get it to budge. Eventually I found a you tube thread of a chinese guy removing the vents from a Z4 with SatNav. It showed there are also 2 black plastic clips in the bottom right and left and when i put a screwdriver in and lifted these (you need 3 hands or 4 screwdrivers) then it finally moved. (Mine is 2004 with standard Business audio).
https://www.youtube.com/watch?v=ro8cU7HMiu0&t=113s
2004 3.0i, manual, toledo blue
Sky-drive
Post by Sky-drive » Tue Dec 27, 2016 3:33 pm
JackB1 wrote:Here is how I removed mine - it does take someone holding two screwdrivers that are pushing up the metal clips. Then you have your hands free to pull the vent assembly straight out towards you. I got a piece of string through, around the back and out again (string not shown), then pulled on the strings until it came out.
It is like everything else associated with removing in terior parts. unless you have done it before, you really don't know how the fastners work - you really risk breaking things due to the unknown!
Here are some pics -
Hope this helps!
:oldman:
Best!
Jack
Appreciate this is a very old thread now however the photo of the screwdriver pushing up on the metal tabs is bloody misleading and in my opinion should be removed from the forum ...
The OP should have made it very very clear at the beginning of the post that the metal tabs require pulling down, not PUSHING UP.
By following this post I managed to lock the metal tabs upwards on my Zed and ended up having to wrench the centre vent unit out and causing the plastic edge of the centre vent unit to warp. Not a massive issue as the centre vent unit needs replacing anyway as one of the air flap dials is faulty ... I just don't want anyone else to end up in the same predicament I was ...
Xenons | LED S/lights | CF Trim | Royale SW | ZHP | CDV | AUX | DISA | Vanos Refurb | Cruise | MV2s | Roof motor > boot | K&N | Sound Gen | Interior LEDs | E/H seats | Remapped
