Power fold side mirror gets stuck in up position and won't go down
Once folded up (using the button for electric folding) it doesn't want to come back down. It's stuck in the up position.
Anyone know how to fix this?
- z4pilot
Bit more diagnostic info might help the more technically minded folks that might be able to help?
Both mirrors or just one side?
Can you hear any motors running when you press the button?
What happened the last time they folded up - anything unusual?
If both sides, have you checked out the fuse?
Now Gone - 2008 Coupe, Montego Blue, Champagne leather and Piano Black interior, Eibachs & Koni Sport shocks, Style 230 19s, Eisenmann Quad - approaching perfection...
Just the passenger side one.
When pressing the button to get it down again, no can't hear anything.
Nothing unusual when folding up ever.
- left98204
Exactly the same thing has happened to mine.
I can catch it half way and unfold the mirror again, but as soon as it has gone fully up, it wont come back down again
54 Plate 2.2 SE, Titanium Silver, retro fitted Heated, Electric MSports Seats, Gaptech, Cruise Control, 108's - Owned from new
Mine will come down again but only by hand
Onlinekis
Bump
My passenger mirror won't fold either. Well actually it does but works intermittently...
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- flimper
Same thing just happened to me
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
Onlinekis
I took mine off, removed the mirror cover and then submerged it in a bucket of hot soapy water (well I was washing the car anyway). Gave it a good scrub as it was filthy - probably the best part of a decades worth of grime. And left it to dry before spraying some of my chain lube on it (motorbike stuff).
Back on the car and working again. I pumped more lube in and operated the fold unfold button a few times to get the lubricant as far into the motor mechanism as I could.
I'll probably do the same again this summer
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- flimper
Is it easy to do? Any pics?
mine fixed itself !!
Onlinekis
Yeah pretty easy. Depends how far you want to go, you could take the whole thing off if you wanted. But probably better left in situ.
If you're taking it off in situ, the mirror comes off (that's kind of complicated if you've never done it - theres a guide somewhere). Then some screws come out of the bottom and middle section of the mirror cover. This means the cover (2 sections) comes off and you've got access to the main body of the "mirror". It's actually quite complex to explain!
I'll repeat over the summer and take some pics then
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Is there a way to open up a gap so that you can spray some lube into the right place?
Onlinekis
Maybe? If you undo the black part of the mirror cover (at the bottom so long as you've not folded it). I think it's just one screw. You want to lubricate the section that rotates, so if you get somone to powerfold it, so you can see where it's pivoting then you know where to spray. I'm not sure this will be sufficient... i.e. You probably should remove it completely to get unrestricted access, but it's better than no lubricant at all!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Callahan
Same thing has just happened to mine! Was all working fine but suddenly the drivers side doesn't move at all, no motor noise, nothing! I've also noticed that the heated mirror isn't working but the mirror tilt does? I've checked the fuses and they're all fine. (Passenger side all works fine.)
Kis, when you say you took yours off do you mean dismantling the wing mirror assembly itself while still on the car, or removing the entire wing mirror from the door?
Onlinekis
When I originally did mine I wanted to inspect everything. So I took it off, that involved taking off the whole door card. There are 2 or 3 bolts behind the little tweeter you need to take them out and the cable runs down inside the door so had to take the card off!
If it's still working I'd say you can do it in situ but you need to remove mirror, black mirror cover and the colour coded mirror cover sections. Then clean and re-lubricate.
If it's not working then you need to try revive the motor. I've heard soaking in diesel should do the trick... so if all else fails then leave it in a bucket overnight...
Like I said I'll do mine again at some point... so can post pics then. If you want tho it's straight forward
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
