Enjoy!veilside85 wrote:
It will be my first time around it.im happy now I have found a set up I'm pretty confident with.
kW v3 coilovers
- exdos
kW v3 coilovers
- veilside85
kW v3 coilovers
them ramps look a good idea saves jacking the car up
Silvergrey/imola/carbonleather/pss/stubby/carbonspoiler/black grills/aeroskirts/vibratechnics/hel brake lines/pagidrs29/kwv3/stud conversion/
- MrPT
kW v3 coilovers
Awesome. Is that...veilside85 wrote:All sorted gone for 12/11 front 9/8 at the back and lowered the front 5mm on the front feels like it's on rails now
Front rebound: 12 (out of 16 clicks open)
Front bump: 11 (out of 12 clicks open)
Rear rebound: 9 (out of 16 clicks open)
Rear bump: 8 (out of 12 clicks open)
Would be interesting to hear if you ever max out the suspension travel with those bump settings. They do seem to provide a really good balance of handling and ride comfort when set that soft, especially on those MPSS (that's how mine came from the previous owner).
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- veilside85
kW v3 coilovers
Still a learning curve for myself.ive got it where I have confidence in the car now.I was lacking it this morning just didn't feel right.would you recommend dialling out the bump abit?MrPT wrote:Awesome. Is that...veilside85 wrote:All sorted gone for 12/11 front 9/8 at the back and lowered the front 5mm on the front feels like it's on rails now
- exdos
kW v3 coilovers
There are at least three places around the Nordschleife you are likely to bottom out the suspension, even on the stiffest settings, especially if you have the added weight of a passenger.MrPT wrote: Would be interesting to hear if you ever max out the suspension travel with those bump settings. They do seem to provide a really good balance of handling and ride comfort when set that soft, especially on those MPSS (that's how mine came from the previous owner).
- MrPT
kW v3 coilovers
Good to know!exdos wrote:There are at least three places around the Nordschleife you are likely to bottom out the suspension, even on the stiffest settings, especially if you have the added weight of a passenger.MrPT wrote: Would be interesting to hear if you ever max out the suspension travel with those bump settings. They do seem to provide a really good balance of handling and ride comfort when set that soft, especially on those MPSS (that's how mine came from the previous owner).
To the OP - I'd not play about too much until you've had the chance to drive one setup on a variety of roads. You could take one of the following approaches, which many people have suggested on forums -
* Use the recommended settings as a starting point and fully get a feel for them before changing, one step at a time
* Go nearly to the softest settings all round and then slowly increase the rebound until you can feel the car stabilise over medium speed bumps, and then perhaps start becoming a bit "bouncy" - at which point, dial it back a click
Personal preference, I guess, plus the types of roads you drive on.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- veilside85
kW v3 coilovers
one photo from the ring last weekend.think I'm gonna have to invest in some decent track tyres,also took me a few attempts to get the ride height and settings just right where i could start enjoying the track and slowly start pushing it more.
what a amazing place
- MrPT
kW v3 coilovers
Nice! Where did you end up, settings-wise?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- veilside85
kW v3 coilovers
15/8 12/6 biggest improvement was tyre pressures dropped them down to 28psi. Think new anti roll bars next hopefully get rid of some of the role.
Gonna have to dial the rebound down abit for the uk roads.
- BMWZ4MC
kW v3 coilovers
I found that the H&R ARBs fitted with Eibach springs and standard shocks but not with KW Clubsports. It was fairly easily fixed with adjustable droplinks, so you might find the same with V3s.veilside85 wrote:15/8 12/6 biggest improvement was tyre pressures dropped them down to 28psi. Think new anti roll bars next hopefully get rid of some of the role.
S2000 GT - gone
kW v3 coilovers
I installed a set of V3s on my car last year and had the geo set up by center Gravity. All the adjustments were in the middle of the range. A friend and I did some back to back driving on a bumpy and curvy B road near his home. He is a keen track day driver and raced a GT3 in the VLN series at the Ring for 4 or 5 years a while back. He knows how to pedal. Many years ago I used to be faster around the Ring in my Caterham than he was in a 964RS but he now runs away from me on the track.
We tried 4 cars - my Z4M coupe, a new BMW M4, a nearly new Cayman GT4 and a 20 year old Lotus Elan Turbo on Ohlins. Guess which car was the scariest, most ready to spit you off and feeling least in contact with the tarmac?
The Z4M!
The car's only just come out of its winter hibernation so experimentation with softer settings is very much in the plan.
PS. The most composed car was the Elan - pretty good for a 20 year old FWD cabrio. Lotus does know a thing or too about suspension design.
The Z4M!
- MrPT
kW v3 coilovers
Sounds like a fun experiment. Still on MPSS and the OEM alloys?monaco_blue wrote:I installed a set of V3s on my car last year and had the geo set up by center Gravity. All the adjustments were in the middle of the range. A friend and I did some back to back driving on a bumpy and curvy B road near his home. He is a keen track day driver and raced a GT3 in the VLN series at the Ring for 4 or 5 years a while back. He knows how to pedal. Many years ago I used to be faster around the Ring in my Caterham than he was in a 964RS but he now runs away from me on the track.
The Z4M!
I can believe the the Elan felt the most composed. It was always famous for point-to-point speed and I'm sure a lot of that came from driver confidence.
I think the Z4M was just born to be wild. Something about the iron lump in the front, the rearward driving position and the staggered tyre setup. Lap times suggest that it doesn't give much away on track, but I suspect on track you can really make the most of car pitching backwards and forwards, rather than the unsettling feeling you get on the road of the front pushing on and/or the rear going light. Perhaps a more square tyre setup would help?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
kW v3 coilovers
Yes, still on stock alloys and Conti SportContacts, fairly fresh on all 4 corners. Prior to fitting the V3s the car was a little scary - wheel spin at 70mph in the rain is a bit sphincter clenching when it's unexpected. The V3s helped and then the proper geo (road focused rather than maximum corning grip) helped a bunch more and the car feels much more consistent and stable. Until it gets real bumpy and then the suspension (on its current settings) feels overwhelmed by what's being thrown at it. Just out for a hoon this morning and under power the traction light flashes on a bumpy straight section of B road. My V10 M5 handles that without getting its knickers in even the slightest of twists.
I do like that the Z4M has to be "worked" to be driven at speed - I've no problem with that and rather enjoy it. But a bit more composure when the road isn't billiard-table smooth would be nice. The ride and composure of the Cayman GT4 are astonishingly good considering its capabilities.
- veilside85
kW v3 coilovers
Like you mentioned I use to be able to light the tyres up on stock suspension with the v3's it has so much more traction.monaco_blue wrote:Yes, still on stock alloys and Conti SportContacts, fairly fresh on all 4 corners. Prior to fitting the V3s the car was a little scary - wheel spin at 70mph in the rain is a bit sphincter clenching when it's unexpected. The V3s helped and then the proper geo (road focused rather than maximum corning grip) helped a bunch more and the car feels much more consistent and stable. Until it gets real bumpy and then the suspension (on its current settings) feels overwhelmed by what's being thrown at it. Just out for a hoon this morning and under power the traction light flashes on a bumpy straight section of B road. My V10 M5 handles that without getting its knickers in even the slightest of twists.
Has any one fitted kW arbs ??
- Beedub
kW v3 coilovers
they didn't ofer ARB when i got my CS dampers, has that changed now?veilside85 wrote:Like you mentioned I use to be able to light the tyres up on stock suspension with the v3's it has so much more traction.monaco_blue wrote:Yes, still on stock alloys and Conti SportContacts, fairly fresh on all 4 corners. Prior to fitting the V3s the car was a little scary - wheel spin at 70mph in the rain is a bit sphincter clenching when it's unexpected. The V3s helped and then the proper geo (road focused rather than maximum corning grip) helped a bunch more and the car feels much more consistent and stable. Until it gets real bumpy and then the suspension (on its current settings) feels overwhelmed by what's being thrown at it. Just out for a hoon this morning and under power the traction light flashes on a bumpy straight section of B road. My V10 M5 handles that without getting its knickers in even the slightest of twists.
