S54 rod bearing
"M" Specific discussion
Smartbear
S54 rod bearing
Post by Smartbear » Mon Feb 06, 2017 10:48 am
DMC63 wrote:
VRSteve wrote:
DMC63 wrote: Is this a problem just with Ms? Should I worry about a 2003 2.5i ? :?
Nah.
If that goes pop you can buy an M.
Win win!
:rofl: I'd like an M. But I'm a few quid short and I don't like the disabled special needs steering wheel and I want a soft top on it.
It's possible to buy an M with a soft top :thumbsup:
e85 3.0si sold
VRSteve
S54 rod bearing
Post by VRSteve » Mon Feb 06, 2017 1:50 pm
Smartbear wrote:
DMC63 wrote:
VRSteve wrote:
Nah.
Win win!
What's wrong with the steering wheel???
///M|Silver Grey|Black Leather|BT|Nav|DSP|Heated Seats|PDC|Stubby|Turner Limiters|Turner Rear Top Mounts|Bilstein B12|Powerflex ARB Bushes|Powerflex Lollipops|M-Track|
SOLD
GuidoK
S54 rod bearing
Post by GuidoK » Mon Feb 06, 2017 1:59 pm
DMC63 wrote: Mines at 84,000 miles. So I've got a bit of time yet then? How comes others are saying change at 80K Kilometers. Are you sure 300k miles is ok for my car? I know there's a joke in there somewhere but It's gone over my head due to my lack of knowledge on this :?
Your engine code is what most people call the 'M54' engine (and the 2,5L model is called specificly M54B25)
So if you see problemtopics relating to M54 engines here on the forum, thats when you want to pay attention :wink:
This problem is only applicable on the S54 engine and is found in the z4m (and e46 M3), and some other S50/S65/S85 engines, but of no real concern to the M54 engine range
DMC63
S54 rod bearing
Post by DMC63 » Mon Feb 06, 2017 9:24 pm
Smartbear wrote:
DMC63 wrote:
VRSteve wrote:
Nah.
Win win!
Yeah, but what about the special needs steering wheel?
BMW Z4 2003 2.5i and lots of bits and pieces - 2016 - 2020 Sold
Smartbear
S54 rod bearing
Post by Smartbear » Mon Feb 06, 2017 9:27 pm
What do you mean by that? :?
e85 3.0si sold
DMC63
S54 rod bearing
Post by DMC63 » Mon Feb 06, 2017 9:39 pm
It's got controls all over it and it's too fat. I hate the paddles and buttons on a steering wheel. It looks s**t, especially in a roadster. When they start to add gadgets to a sports car it turns into a Dad car. That's why I like the 2003 pre-facelift with the bare steering wheel, no heated seats. Bare essentials. Look at all the good old roadsters. Bare bones. A fun car to drive with no bells or whistles. Nowadays it's all about comfort without consideration for looks. The 'average Joe' buys for comfort more than looks.
I think the brushed ali and basic leather trim nailed it. tbh, ali floors without carpets would've been cool too. Imagine the 2003 interior in an M. That would be nice. Fast and functional. None of this comfort crap! Well, you asked :oops:
DMC63
S54 rod bearing
Post by DMC63 » Mon Feb 06, 2017 9:42 pm
Phew! Thanks for that info, and the tip for engine code. Might be giving the M a miss then and stick with supercharging mine. :thumbsup:
Smartbear
S54 rod bearing
Post by Smartbear » Mon Feb 06, 2017 10:01 pm
DMC63 wrote:
Smartbear wrote:
DMC63 wrote: Yeah, but what about the special needs steering wheel?
So I take it your car doesn't have air conditioning then? All that comfort crap is no good you know :wink:
e85 3.0si sold
Kernow-Z4
S54 rod bearing
Post by Kernow-Z4 » Tue Feb 07, 2017 10:13 am
Morning guys,
Ive just enquired with a local independent about getting rod bearings done as a preventative measure.
What has confused me is he came back with a quote for changing the problematic s54 Rod bolts only. I questioned him asking about the bearing shells being replaced and he said he would only reccomend it if they showed signs of wear.
Correct me if im wrong but i was under the impression that the issue on the s54's is with the bearing shells wearing out and nothing to do with the rod bolts? The bolts only get replaced if the beairng shells are?
Can anyone shed any light on this? :)
2006 Z4 ///M Coupe, Interlagos Blue, Black Leather, Eventuri intake and Stromung Exhaust
Smartbear
S54 rod bearing
Post by Smartbear » Tue Feb 07, 2017 11:12 am
I thought when the m3 using the same engine started having problems, bmw issued a modified bolt set for the big ends (I think the old ones stretched?)
Apparently they didn't extend this the the z4m using the same engine, later car's had the different bolts from the factory I believe.
e85 3.0si sold
VRSteve
S54 rod bearing
Post by VRSteve » Tue Feb 07, 2017 11:31 am
Smartbear wrote:I thought when the m3 using the same engine started having problems, bmw issued a modified bolt set for the big ends (I think the old ones stretched?)
You're right....the bolts were changed in 2003 so given that the Z didn't get the engine until 2006 I can't imagine the Z would have ever needed a recall on them.
The bearings can spin due to the bolts stretching, but if you're going to the effort of dropping the sump and changing the bolts why on earth wouldn't you change the shells too??
SOLD
Smartbear
S54 rod bearing
Post by Smartbear » Tue Feb 07, 2017 11:47 am
I thought the early z4m's were fitted with the stretchy bolts? I seem to remember owners being really irked that bmw didn't treat them in the same manner as the m3 guys.
e85 3.0si sold
VRSteve
S54 rod bearing
Post by VRSteve » Tue Feb 07, 2017 11:57 am
Don't know! Be helpful if someone knows for sure, Mines an early 2007 so assumed that mine would be OK, but now I'm wondering!
SOLD
AndyBeech
S54 rod bearing
Post by AndyBeech » Tue Feb 07, 2017 12:46 pm
That would make no sense at all? :rofl: Why would they fit a pre 2003 engine to a 2006 car when all engines they made after the bolt recall came with the new design? If you look at a lot of the engine parts on RealOEM the Z4M has most of the last iteration parts fitted that they designed for the S54. Bosch coils instead of the potentially troublesome Bremi coils for example (think that's the right way around).
Where's this info of irked Z4M owners?
http://www.realoem.com/bmw/enUS/part?id ... 1247834310
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
Kernow-Z4
S54 rod bearing
Post by Kernow-Z4 » Tue Feb 07, 2017 12:51 pm
Ive done abit more digging and regarding the bolts pre Feb 2003 engines used an m11 sized rod bolt and post Feb 2003 S54's used an M10 sized bolt. The Z4M uses the M10 Sized Bolt so one can hopfully assume that the S54 in the Z4m is the stronger of the bolt.
Interestingly if you have the M11 Sized bolt when the rod bearing shells are changed BMW Recomends that the rod bolts are not replaced and the orignianls put back in.
However if you have the M10 sized bolt replacments are required everytime you change the rod bolts due to them needing to be tensioned 3 times at different torque values to achieve the correct length.
