First ESS Supercharged N52 Z4 dynoed
- Beedub
Re: First ESS Supercharged N52 Z4 dynoed
or to really chill it down.... water injection?? bmw using it on their new gt4... could work here too
- bmwZ
bmwZ wrote:That will be my next mod:) But don't think bonnet vents will be clean enoughba3bas wrote:Bonnet vents??
To be honest for a first stab im impressed.
You could always get an air duct from the grill to the filter and make a heat shield on the engine bay side of the filter
- bmwZ
Yeah, but very little space...Beedub wrote:or to really chill it down.... water injection?? bmw using it on their new gt4... could work here too
- Beedub
water injection uses little to no space under the hood.... most systems lot mount a tank or use the washer tank, its literally just a line with a atomised spray nossel, very neat and very easy to implement.
- Brasseye
Looks great. Got a drive by video yet ?
The linear power of super chargers are just so drive able compared to hi boost turbos
Thanks for sharing.
Thanks for sharing.
- bmwZ
I have looked around for maby doing water injection after you came with the idea. ThanksBeedub wrote:water injection uses little to no space under the hood.... most systems lot mount a tank or use the washer tank, its literally just a line with a atomised spray nossel, very neat and very easy to implement.
- pokeybritches
Here's my water/meth injection:
Apologies for the dirty engine bay, as the car was a daily driver.
The water helps cool the intake temps while the methanol is effectively like running race gas all the time. The progressive controller is set so the spray comes on at 4 psi on my car (9 psi is max boost). I used about 10% of the water/meth tank after 2 full tanks of gas. It doesn't take much. Setup is key.
Supercharged Z4 3.0i, 2x Supercharged Z4M
- bmwZ
Thanks for the pics and info. Do you have a nozzle before and after supercharger?
Think I will do that in spring time next year:)
- pokeybritches
Only after. The nozzle should be positioned so it's not spraying directly onto any sensors (I'm not sure what sensors the N52 has). The trunk-mounted tank and pump are actually fastened to a carpeted board, so I can pull the whole thing out in less than a minute. It's very clean.
- ba3bas
- buzyg
Look like a neat set up. Your going to have fun developing that further.
- Beedub
the key OP is to get the nozzle are far away as possible from the intake so literally right after the s/c in your case. You want the fluid to atomize correctly and chill the air down, it also has a lovely effect of steaming cleaning the internals of your engine! WMI can simulate using race grade fuel in the right conditions. Just install it in a way thats unobtrusive so you can remove when you want without any mods to the actual car / wiring.
This is a really cool mod! Could you load a video of the car running with the supercharger? I'd like to see/hear it under the hood at startup, idle, & revs.
- bmwZ
When I'm starting to finish the car I will post a video. The car has always been in pieces either engine, body or interior vice since I started modding it.
My interior is in pieces for the moment, it's time to get started
