Fitting wind deflector - solved 'how to'.
DMike
Post by DMike » Mon Aug 30, 2021 6:13 pm
the_don46 wrote: Mon Aug 30, 2021 8:10 am I am after the part numbers for the brackets, torx bolt and cover cap. Anyone know what they are so I can try find them on eBay? :)
Hi,
Realoem shows the the brackets are included with the wind deflector, 54347117745. Brackets are not listed separately. Brackets for the boot lid have, however, a separate part number, 54347117751, and look quite similar on images, except that there is a L-shaped part attached to them. That could, again looking at images, be easily removed.
2005 Z4 3.0i Sterling grey
DMike
Post by DMike » Mon Aug 30, 2021 6:30 pm
Wen’t to the garage to compare them and the brackets look identical as far as I can see. The boot lid brackets and their L-shaped part are held together by two plastic rivets only.
the_don46
Post by the_don46 » Mon Aug 30, 2021 8:46 pm
Thank you so much for your efforts. I actually have a boot lid set on order so will check it out when it arrives. I eventually found the part numbers for the individual items.
DMike wrote: Mon Aug 30, 2021 6:30 pm Wen’t to the garage to compare them and the brackets look identical as far as I can see. The boot lid brackets and their L-shaped part are held together by two plastic rivets only.
DMike
Post by DMike » Mon Aug 30, 2021 8:50 pm
the_don46 wrote: Mon Aug 30, 2021 8:46 pm I eventually found the part numbers for the individual items.
Did you find a separate part number for the roll hoop brackets (not the boot brackets) too?
the_don46
Post by the_don46 » Mon Aug 30, 2021 8:57 pm
DMike wrote: Mon Aug 30, 2021 8:50 pm
Yeah a guy on FB directed me to a Dutch BMW site which has the part numbers. Link below.
https://bmwshop.ekris.nl/47797-bmw-z4-3 ... LdxOR29SLk
DMike
Post by DMike » Tue Aug 31, 2021 4:19 am
the_don46 wrote: Mon Aug 30, 2021 8:57 pm
Searched realoem with the the part numbers (54347117749, 54347117750) and there are two almost identical diagrams on realoem: One under retrofitting/conversion/accessories and one under folding top section. The folding top section’s diagram has the individual part numbers.
Woodrow
Post by Woodrow » Tue Aug 31, 2021 7:52 am
Homebrw
Post by Homebrw » Fri Mar 01, 2024 4:20 pm
Hello. Sorry to resurrect such an oldie but a goodie, but I wonder if anyone can help me with the hardware (screws)?
I bought the center deflector and the roll bar mounting brackets for my 2006 Z4 MR, but neither came with screws. Can anyone say what they are?
Thanks for the tips to drill.
Chris
enuff_zed
Post by enuff_zed » Fri Mar 01, 2024 4:26 pm
Homebrw wrote: Fri Mar 01, 2024 4:20 pm I wonder if anyone can help me with the hardware (screws)?
Hello,
The answer was actually about two posts up, referencing Realoem.
Screenshot 2024-03-01 152543.png (77.28 KiB) Viewed 272 times
HQ of 'Norfolk Zed Rescue'.
Homebrw
Post by Homebrw » Fri Mar 01, 2024 4:28 pm
Thanks so much for the quick reply! I missed that in the real OEM list... totally glanced over it. Need to slow down sometimes!
Chris
enuff_zed
Post by enuff_zed » Fri Mar 01, 2024 5:31 pm
No prob. Hope you stick around now :thumbsup:
Homebrw
Post by Homebrw » Fri Mar 01, 2024 6:59 pm
Thanks. Just joined a month ago. Then proceeded to spend 3 weeks on EU continent the week after I bought her.
Chris in SC
Homebrw
Post by Homebrw » Sun Mar 03, 2024 3:39 am
Thanks for the help and thread! @sure2drive, your pics helped tremendously. Very nerve-wracking to drill the first hole, but lined up perfectly and after that it was one bit only! Black plug caps on the way.
