Pulsing engine when reversing 35iS
- SO8
Anyone had this - it is difficult to describe but basically when reverse engages and you feather the throttle to move backwards the car almost goes with the throb of the engine like the gearbox / clutch is not right and not engaging properly. I have noticed it a few times and my other 35iS didn't do it. Any ideas ... ? I will mention it to the dealer when the car goes in on 1st June anyway if it keeps doing it ... just wondered if anyone else has had the issue.
Current : BMW M240i Convertible in black and a Smart Fortwo diesel in white
Previous : BMW 35iS in Mineral White and an Mercedes AMG A45 in black
Re: Pulsing engine when reversing 35iS
No such issue with mine. Haven't noticed anything untoward when reversing.
Will have a listen / pay special attention next time to see if I can detect anything.
- SO8
A slight shuddering on taking up the drive in reverse may be another way I could put it ... a bit like clutch judder.
I had this on my 35i DCT some years back. A slight wobble upon first engagement for a second or so. They replaced the DCT eventually after trying new fluid and a reprogram. I think I feel it still now and again or it's probably just in my mind having had it on the first DCT.
It was quite mild but irritating. I asked for a replacement as it made me doubt the longevity of the DCT but in hindsight it was probably nothing more than minor movement in the mounts.
- SO8
Hmmm, ok thanks for the info - I will mention it when it goes in on 1st June !Maniac wrote:I had this on my 35i DCT some years back. A slight wobble upon first engagement for a second or so. They replaced the DCT eventually after trying new fluid and a reprogram. I think I feel it still now and again or it's probably just in my mind having had it on the first DCT.
- jamesbond
Hi
No trouble with mine ...
Born in Yorkshire ended up in Essex .. 35is Mel red now sold
Own 2 big cats (F type & XE S supercharged) looking for a z4 Hobby Car
z4 3.0i 03 - Z4 3.0i 04 - Z4 3.0i 05 - Z4 3.0i 03 - Z3M (s54) 03 Man - Z4M 06 - Z4M 06 - Z4M 07 -
Z4 35is 2014
Z4 35is 2014
- SO8
Just noticed it does it reversing into my drive - so when the steering is putting the engine under load. In a straight line back it doesn't seem to do it .... more checking me feels before I abuse BMW
The car is certainly going well forwards at the moment
- Titan
I experienced similar symptoms with our 35i and manged to alleviate them with an adaptive transmission reset.
Details can be found here:
http://www.bimmerfest.com/forums/showth ... p?t=627076
It's as though the throttle doesn't like the smaller more gentle movements associated with reversing after getting accusotmed to going forwards more quickly
sDrive35i MSport DCT / Deep Sea Blue + White / Mickey Mouse aerial / Smart Top
Michelin PSS / PunctureSafe / 2014 map update
Reversed up my curvy drive a couple of times today - no problems or odness at all.
No problems here either SO8, just a fair old clunk when engaging reverse.
Keep us posted on this please, and I hope it's a simple fix.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- GreyZed
My wife has a 2006 X3 2.5si auto and it does exactly this in reverse but only when engine is cold. If I give it some throttle it goes smooth again although obviously quicker (a little too quick for the reverse out of the garage). Doesn't do it when engine is up to heat though.
3.0 auto, sterling grey, hardtop, prfessional nav, dsp, digital tv, bluetooth, cruise, xenons, mfsw, cupholders, auto lights, auto wipers, folding mirrors, memory seats, wind deflector, pdc, 108s, LED sides/fogs, stubby, intravee, need a quad exhaust!
- JustCruzin
Hmmmm.... odd.... DCT on mine has become a little clunky and there does seem to be a delay in engaging into reverse. I am getting mine booked in shortly. Will let you know how I get on.
JC
JC
Thread revival from many years ago but I cant find a newer one.
My daughters E89 23i is having the same issue as the OP's first post, has anyone had it and solved it?
Current Z4 - 2007 E85 3.0Si
Daily Motor - 2013 Audi A7 BiTDi
- B21
Is it an auto?
Sorry that might help - yes it is.
