Hardwire a dash cam - question about pillars covers
Hello guys!
I am going to fix a dash cam on my Z4 and I would like to hardwire it.
Does anyone know hot to remove the black matt cover of front pillars and also the one around the windshield (where sun visors are)?
I am scared to ruin them doing something wrong.
Any help will be appreciated!
Thank you in advance!
- Number5
Re: Hardwire a dash cam - question about pillars covers
Hi, Welcome to the forum,
If you are looking t mount it up by the drivers mirror, Have a look at my 'How-to' post here....
viewtopic.php?f=31&t=73905&p=1085994&hi ... m#p1085994
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- PerryGunn
I thought about linking to your how-to Alan, but the OP has posted in the E89 section so it might be different for themNumber5 wrote:Hi, Welcome to the forum,
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
- Number5
Good SpotPerryGunn wrote:I thought about linking to your how-to Alan, but the OP has posted in the E89 section so it might be different for themNumber5 wrote:Hi, Welcome to the forum,
In that case, it may be the same as my 2011 520d (F11) He'll just need the green&brown wire instead of the violet & white one, but everything else is the same procedure.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
If you need to feed wires down the side pillars, like I did to take a feed from the dome light, just pull off the rubber door seal and there is enough gap to feed a wire without removing the black plastic trim.
Hello guys....
Thank you for your reply: I need to remove the black plastic trim from pillars because I need to reach the fuse box. Plus I have a dash cam with 2 ch...so it means I need also to make the power wire to run from rear camera to front one.
Any suggestion about how to remove safely the black trims from pillar will be very much appreciated.
Am looking to do this shortly with my 2CH Blackvue DR-650. Out of interest, where are you planning to place the rear camera on you Z4?lukas_4942 wrote:Hello guys....
- jimbo1958
Another job I would like to do on mine. Keen to see it on another E89 first as I can't abide wires on show.
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Jaguar F Type V6s Roadster
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
Number 5, I have all the components and am currently looking at the wire looms, unable to identify the green and brown wire. (BMW Z4 E89). I’ve been using your other guide and I believe as soon as I locate a wire to piggy back off using the connector I’ll be all good. Can you help at all / take a picture? Thanks a lot!
Number 5, these are the two clusters of wires. Any idea?
- 7CDDA9FB-6046-44BB-896E-39A7D3CCE4B1.jpeg (303.7 KiB) Viewed 4153 times
- 9523466C-8C08-4B83-B361-39F092691D65.jpeg (258.04 KiB) Viewed 4153 times
