Retrofit Cupholders (half finished!)
- Greeno
Re: Retrofit Cupholders (half finished!)
It is probably still worth a call to the dealers to see if they can get the face plates as the info might be incorrect
"Rules are for the guidance of the wise and the obedience of fools"
- kernel-debugger
I would recommend them all day long, they come in handy in summer & winter. You can use the vents to either cool the drink or heat them up depending on your drinks choice and time of year etc.... They also have an adjustable grip so no matter what size of cup you use they sort of ratchet to the cup size and grip firmly. Simply push them in when you're finished with them. A note worth making though.....don't forget to push them in before getting out of the car. They get in your way and you're more likely to break them off whilst exiting from the car.
BMW Z4 3.0si Sterling Grey, 6 speed manual, comfort pack, sat-nav, multi disc + M Sport Extras[/color] Now with private reg - T24 DJE
- bat1959
Face plates are now available, collected and fitted mine today.Greeno wrote:It is probably still worth a call to the dealers to see if they can get the face plates as the info might be incorrect
2004 3.0i SE, My MOD's: Gaptech remote/one touch, MFSW, Cruise, brake light ring mod, OEM strut brace (black), OEM MP3 capable head unit & Stubby.
- Wondermike
- Moderator
Wow that took a long time. Good info
- pvr
You can talk ... 3 years later you still have not finished your retrofit process ...
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Wondermike
- Moderator
Yeah I should change the title, 'cos everyone else posting their info has finished it off.
I don't think preparing a "how-to" is one of my stronger points, along with choosing a good car colour or picking the right time to buy and sell.
- Farao
Did mine today in less then half an hour. I know need to see whether the system works with sporty driving
Thanks for the guide, took no time at all.
For completeness, here are the part numbers (driver's side) and current prices at my local dealer:
Drink holder - B51.45.7.070.324 - £32.10
Front cover (replaces the blanking plate) - B51.45.7.056.652 - £0.17
Screws - B65.75.8.235.255 - £8.90
- WLH
X2 as real tall cups just don't work very well and should be avoided.561design wrote:What kind of rocks do you guys drink? I love my cup holders and put al sorta stuff in them. The only time I get concerned is when the cup is tall. The cup then becomes top heavy because the holder itself is shallow.
About the rattle. I've never had that problem but one member in our local club who claimed he had that problem with certain drinks lined the inside of the holding arms with the soft side of velcro tape.
- teamemmenracing
Just fitted 2 cup holders as well ........... took about 5 mins each side.
Likewise I need the 2 face plates,I was tempted to make something using modified blank plates but decided to keep the blamk plates intact, never know when you might need them.
"........it seemed like a good idea at the time yer honour ......"
BMW Z4 - A Big Red One
- ZedFourM
Are those prices the right way around? 17p for the front cover, but over 8 quid for the screws???chrismox wrote:Front cover (replaces the blanking plate) - B51.45.7.056.652 - £0.17
Philip
Have you all gone nuts? You let passengers actually eat and drink inside your Zed!??
2008 Z4 2.0i SE E85, Space Grey, 18" 241 staggered rims, 255/35/18, 225/40/18, 2 tone anthracite/silverstone leather Msport heated seats, M sport MFC Steering wheel, Bluetooth, Comfort pack, Tracker, Automatic climate control, Gaptech, Blah, blah.
- Z4MO
Buy them from the dealer, I paid £95 for both.BMW_Z4_Norway wrote:Where can I buy some and are they hard to fit by yourself?
Very easy to fit. Undo one screw and pull out air vent, attach cup holder to the bottom of the air vent using supplied screw and slot back in. I think there will be a fitting guide on here somewhere and you will get them with the holders
2006 Black / Black Z4M Roadster
- ieatanimals
Hi. Will these fit the E89 2013 plate?
