How to Wire in a Dash Cam (E85/E86)
- Rorybeanbutler
- Number5
No, sorry. I didnt quite understand the question really ?Rorybeanbutler wrote:Any help/ideas?
???Rorybeanbutler wrote:Which cable in my next base box should I be useing for this? I have a hdmi cable. A micro usb/usb and the lighter socket connection. Or do I need to get another cable? Im A bit of a newb with wiring.
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- markeg
I would expect that the micro usb is the power input for a 5v supply to the camera, and that the HDMI is an output to a HDMI display - for playing the video files from the camera.Number5 wrote:No, sorry. I didnt quite understand the question really ?Rorybeanbutler wrote:Any help/ideas?
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- Rorybeanbutler
Which cable did you use for this. It's not complicated really. None of the pictures quite show which one of the cables in my next base box you used to wire it in.Number5 wrote:No, sorry. I didnt quite understand the question really ?Rorybeanbutler wrote:Any help/ideas?
z4 coúpe gone. C30 r design arrived.
- Number5
I linked the red+ from the USB Power Supply to the white&Violet wire. I thought this was in the OP ??Rorybeanbutler wrote:Which cable did you use for this. It's not complicated really. None of the pictures quite show which one of the cables in my next base box you used to wire it in.Number5 wrote:No, sorry. I didnt quite understand the question really ?Rorybeanbutler wrote:Any help/ideas?
- Post some photos maybe ?
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Rorybeanbutler
The usb that came with it is just that a usb. There is no red cable.
Thank you Number5 for your instructions.
I've just followed these this evening and fitted my dash cam into the Z4. I brought this 5V mini USB adaptor on eBay as the converter package was so small. But the length of the USB cable wasn't long enough, so the converter module isn't hidden away and instead is sitting above the mirror. But its small and fairly neat and not too obvious. I also brought this one as it has a right angled USB connector, but it angled the wrong way, which meant the cable had to loop. It was only £2.89 delivered, so I might by another with a longer USB cable.
Anyway, its in and working now.
__________
2003 Z4 3.0i, titan silver with black leather, DLV exhaust, Royal steering wheel retrim.
- PerryGunn
That's very similar to the one I got - when I ordered mine they had them with 90 degree and 270 degree right-angled connectors. I didn't want to loop the cable and I couldn't work out which one I'd need, but they were dirt cheap so I ordered both - I still don't know which is the correct one because they weren't labelledd3matt wrote:Thank you Number5 for your instructions.
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
Sorry for bringing this old post up, but I followed the instructions and it went very well. Used the Scotch lock as mentioned on the purple and white cable. It was touch and go to star with as the crimp didn't cat has at first, but I pressed it down again and it worked well. I used a couple of small cable ties and a sticky sided cable tie holder to hold the psu in place in the coupes roof. Put some insulation tape around the Scotch lock to keep it insulated. So a big thanks and fingers crossed that it stays problem free.
2006 Silver-grey 3.0si coupe including miles of smiles.
- heavymetalthunder
I successfully wired in my dash cam with these instructions, many thanks Although I routed my USB cable directly up to the roof cavity bit as that was neater/more direct route than going through the mirror housing.
I used an A118C camera, quality isn't as good as the G1W that I had in my old car, but that was a bit bulky and I wanted something a bit smaller/unobtrusive for the Zed. And this is the USB regulator that I used: http://www.ebay.co.uk/itm/130972209135
I attach a couple of photos to show the install.
- IMG_3291.jpg (130.38 KiB) Viewed 6222 times
- IMG_3284.jpg (87.72 KiB) Viewed 6222 times
E85 Z4 3.0i Roadster (manual) in Sterling Grey
hi thanks for the info....after doing it did you get any error messages
- vester86
Nope, not in my case
When I fitted mine I picked up,feeds from the fuse box behind the glove box if that's any help. You remove the sunvisors then the plastics , then you can route through to the fuse box. I used this
http://www.ebay.co.uk/itm/Add-A-Circuit ... 1c6c7985dc.
Regards
Regards
Sterling Grey 3.0i E85 Black Heated Leather M sports seats , 224's ,Sat Nav, Bluetooth, Xenons, PDC, Gaptech ,Cruise and a nice warm garage. NOW GONE
Silver 3.0i Z4 NOW GONE
- TR4man
Just followed these instructions and the whole job took no more than 20 minutes - many thanks Number5
2006 E86 Si Sport as a daily driver.
Darn photobucket! I don't suppose anybody was able to rescue a copy of the guide and pictures before the hosting went down?
