deflectors for Zenon headlights?
- AlexRWD
Off to Germany tomorrow, does anyone know if the standard deflectors from Halfords etc will work with Z4 Zenons, or do you need special (and doubtless overpriced) deflectors from a main stealer?
Merc SL55 AMG
previous cars: Interlagos blue Z4MR, TVR Tamora
- AlexRWD
Ok, I'll check the handbook before asking next time
Found reference to removing wheelarch cover for headlights, which I did, you're then supposed to be able to find a switch that you flick up for driving on the continent - buggered if I could find it though
- anyone else managed to find it?
Merc SL55 AMG
- davidpfitz
- davidpfitz
- AlexRWD
Nope, afraid I didn't find it - bought some of the Halfords deflectors as mentioned by David, which are quite a thick tough looking plastic, and they specifically say they are for Zenon Z4's onlyR32Paul wrote:Alex,
Did you find the magic switch?
Merc SL55 AMG
- pvr
why bother? I go to the Continent about 10 times a year, never change it.
Car is too low really to blind ...
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
I live in Belgium at the moment, but the car is from the UK, so as the nights draw in I have a lot of travel in the dark...
Anyway, I found the magic switch at the weekend!
If you remove the wheel arch cover, then the separate headlight cover (pretty tight) get your hand in to the OUTSIDE of the outside light - in between the two threads you can find the switch, flick it up or down.
Note that you cant actually see it, unless you happen to be a dentist and use one of those teeth mirrors they have
Randal
