As per previous threads I picked up my new Z4M last week and have a couple of queries
1: See you home lights - I only tried this once but only the drivers side light came and stayed on - is this correct?
2: I think the two headlights have different bulbs in as one is a very white/blue light whilst the other is more yellowy - again i only noticed this quickly at the same time as i did the see you home light - as they are xenons how easy is it to change so that they do match if i notice it again?
3: Sticky handbrake: when i go to pull away for teh first time it feels like the hill assist is one even when on the flat so i assume i have a sticking caliper on the right rear - would this be normal brakes or the handbrake inside the drum?
apart from that i am loving being back in one again
A few queries
A few queries
Hello, i don't know about 1 and 2, but 3 yes hill assist is always on , even on flat ground, you can "test" it, it only holds you if you press the brake a little hard. then holds you for about 2 seconds.
- buzyg
